iptechnology
Forum User
- Joined
- Jul 6, 2016
- Messages
- 12
- Reaction score
- 13
Please, give us a "linux style" intelligent phone template override system.
I try to explain it with an example:
- Yealink Phone with default template
Every customer want a different DSS Transfer type or ringtone, it means 2 lines config changes.
Now we have to duplicate the base template, edit it and apply the changes. If you update the base template, we have to find out the changes we previously made, duplicate the updated template, re-edit and apply it.
It takes long time and can create problems while it should take 2 minutes working.
My idea for simple changes like the one above, is to put them in a SEPARATE file that is pharsed AFTER the base one and it overrides the single changed values.
Config files of Linux service like apache works natively as described.
override file example:
------- yealink.override1----------
#Define the way of DSS key when configuring as a transfer key; 0-Display Number, 1-Attended Transfer, 2-Blind Transfer (default);
transfer.dsskey_deal_type = 1
distinctive_ring_tones.alert_info.2.ringer = 2
distinctive_ring_tones.alert_info.3.ringer = 2
distinctive_ring_tones.alert_info.4.ringer = 2
Alessandro Coelli
IP Technology srl
www.iptechnology.it
Alessandro Coelli
IP Technology srl
www.iptechnology.it
Upvote
78
