Intercom and Outbound rule clash
Discussion in '3CX Phone System - General' started by Henk, Jul 8, 2008.
  1. Henk
    Henk Member
    Nov 13, 2007
    - sbs 2003
    - Phone AT-520
    When using the intercom function in 3CX it opens two lines, one to the phone I want to use as an intercom and the other to the PSTN line.
    I use outbound rule digit 9 to enable the PSTN direct calls, and obvious this clashes with the intercom function 9<extension>
    Fix (suggesting)
    When 9 is outbound rule, check for the digits dialed and if same as extension digits length use intercom otherwise dial out.
    (something like that, or disable 9 as part of the ability of outbound rule).
    ====edit ==========
    Ooops jumping the gun, forgot the *, seems to be working as it should be. Sorry.
    I am back into my box now
    =========end edit============
