Intercom Dial Code missing
Discussion in '3CX Phone System - General' started by Badgerdata, Feb 19, 2018.
  1. Badgerdata
    Feb 19, 2018
    I'm new to 3cx. Using free hosted pbx version.
    I am trying to place an intercom call to a Fanvil 4X phone by dialing *9 + Extn.
    Error I am getting is: "02/19/2018 7:21:06 AM - [Flow] Target endpoint for *9222 can not be built!"
    In other threads I read that there should be a dial code in for *9 but I don't see that listed with the other dial codes.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Badgerdata
    You need to add the dial code then. Just go to Management Console >> Settings >> Dial Codes and add the dial code you want (*9 in this case) in the Paging field.
  3. Badgerdata
    Feb 19, 2018
    Thanks, that works!
    Is it possible to place an intercom call to a 3cx client?
  4. mariosM_3CX
    Nov 1, 2017
    406
    38
    Yes sure, this is possible.
  5. Badgerdata
    Feb 19, 2018
    When I place an intercom call to an android 3cx client it rings the phone instead of going off-hook?
  6. mariosM_3CX
    Nov 1, 2017
    406
    38
    Apologies for that, i meant with the windows 3cx client.
