Intercom in V9 (resolved)
Discussion in '3CX Phone System - General' started by FGCUHank, Aug 21, 2010.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    I recently upgraded from V8 to V9 with the 2 user demo license. In V8 I was able to intercom between my polycom phones and 3cx soft phones. Currently on 3CX Phone System v9.0.13373.540
    Since the upgrade I don't seem to have intercom capability anymore. Even tried installing a new demo license.
    Here are the log entries from a call from a polycom phone to a 3cx soft phone.
    Any help or feedback would be greatly appreciated.
    23:56:52.671 [CM505001]: Ext.19: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.11015.0] PBX contact: [sip:19@127.0.0.1:5060]
    23:56:52.671 [CM503002]: Call(7): Alerting sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76
    23:56:52.281 [CM503025]: Call(7): Calling Ext:Int.19@[Dev:sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76]
    23:56:52.234 [CM503004]: Call(7): Route 1: Ext:Int.19@[Dev:sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76]
    23:56:52.234 [CM503010]: Making route(s) to <sip:*919@192.168.3.4>
    23:56:52.234 [CM505001]: Ext.17: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_320-UA/2.2.2.0084] PBX contact: [sip:17@192.168.3.4:5060]
    23:56:52.218 [CM503001]: Call(7): Incoming call from Ext.17 to <sip:*919@192.168.3.4>
    23:50:59.827 [CM503008]: Call(6): Call is terminated
    23:50:53.671 [CM503002]: Call(6): Alerting sip:17@192.168.3.98:5060
    23:50:53.437 [CM503004]: Call(6): Route 1: Ext:Int.17@[Dev:sip:17@192.168.3.98:5060]
    23:50:53.421 [CM505001]: Ext.14: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_550-UA/2.2.2.0084] PBX contact: [sip:14@192.168.3.4:5060]
    23:50:42.812 [CM503003]: Call(5): Call to sip:17@192.168.3.4 has failed; Cause: 487 Request Cancelled; from IP:192.168.3.98:5060
    23:50:33.843 [CM505001]: Ext.17: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_320-UA/2.2.2.0084] PBX contact: [sip:17@192.168.3.4:5060]
    23:50:33.593 [CM503025]: Call(5): Calling Ext:Int.17@[Dev:sip:17@192.168.3.98:5060]
  2. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Re: Intercom in V9
    Here is a log of the same call, polycom to 3cx softphone in debug mode
    00:14:26.281 [CM503003]: Call(9): Call to sip:19@192.168.3.4:5060 has failed; Cause: 487 Request Terminated; from IP:127.0.0.1:5080
    00:14:25.812 [CM503008]: Call(9): Call is terminated
    00:14:23.874 Currently active calls - 1: [9]
    00:14:23.218 [CM505001]: Ext.19: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.11015.0] PBX contact: [sip:19@127.0.0.1:5060]
    00:14:23.218 [CM503002]: Call(9): Alerting sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76
    00:14:22.827 [CM503025]: Call(9): Calling Ext:Int.19@[Dev:sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76]
    00:14:22.781 [CM503004]: Call(9): Route 1: Ext:Int.19@[Dev:sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76]
    00:14:22.781 [CM503010]: Making route(s) to <sip:*919@192.168.3.4>
    00:14:22.781 [CM505001]: Ext.17: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_320-UA/2.2.2.0084] PBX contact: [sip:17@192.168.3.4:5060]
    00:14:22.765 [CM503001]: Call(9): Incoming call from Ext.17 to <sip:*919@192.168.3.4>
    00:06:39.952 [CM503003]: Call(8): Call to sip:19@192.168.3.4:5060 has failed; Cause: 487 Request Terminated; from IP:127.0.0.1:5080
    00:06:31.656 [CM505001]: Ext.19: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.11015.0] PBX contact: [sip:19@127.0.0.1:5060]
    00:06:31.265 [CM503025]: Call(8): Calling Ext:Int.19@[Dev:sip:19@127.0.0.1:55021;rinstance=4072dc989f0b0c76]
    00:06:31.234 [CM503010]: Making route(s) to <sip:*919@192.168.3.4>
    00:06:31.202 [CM503001]: Call(8): Incoming call from Ext.17 to <sip:*919@192.168.3.4>
    00:04:16.749 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.3.4:5060
    23:57:04.781 [CM503008]: Call(7): Call is terminated
  3. matictec
    matictec New Member
    Mar 31, 2008
    188
    Re: Intercom in V9
    As far as i know the 3cx phone do not support intercom.
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,480
    67
    Re: Intercom in V9
    What is 127.0.0.1:5080 ?
  5. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Re: Intercom in V9
    Good question, just noticed that. Ext 19 is a softphone extension.
    But I think the real issue is I may be getting confused on licensing. Does the 2 call demo license actually support intercom?
    I recall testing on my initial install which lets you run a timebombed full license right?
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Re: Intercom in V9
    Hi, 2 call demo license has full commercial features (incl. fax, paging, intercom, call park and call pick-up), but without G729 codec support. Please check your phones, firmware and etc.
    Thanks and Regards
  7. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    I wanted to post back as this is resolved. I uninstalled 3cx, installed the latest V9 release, installed a backup that I took from my V8 system and then installed the 2 user code.
    This resolved the issue. I must have smacked something in the provisioning directory.
    I now have intercom between polycom and the 3cx phones.
