Intercom
Discussion in '3CX Phone System - General' started by kalepost, Jan 10, 2010.
  1. kalepost
    Jan 9, 2010
    I was looking at installing a voip phone system and found 3CX. I was looking at the free edition vs paid edition page and saw that there was not a check by intercom for the free edition. So in the free edition there is no intercom at all?
    -thanks
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Correct. The Free Version should really be called test version or evaluation version. It has some features limited so that it is not applicable for production use.
  3. kalepost
    Jan 9, 2010
    Thanks for the reply. -kale
