Intercom
Discussion in '3CX Phone System - General' started by purebulk, Jun 5, 2015.
  1. purebulk
    May 6, 2015
    I have running 3cx pro version 12 service pack 6.2 with polycom soundpoint ip 550/650 phones. Want to setup auto-answer for intercom. *9(ext number) dials the phone but I can't figure out how to get the phone to auto answer.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Unfortunately this feature is not supported by these handsets, so this can't be done.
  3. purebulk
    May 6, 2015
    It is supported and functions on freePBX. If it can work on one platform it should be able to work on other platforms.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    To clarify, those handsets support intercom calls in the manufacturer's own way, which is non standard and differs from the others brands supported, so intercom in the polycom way is not implemented in 3cx at current.
    Kindly post this as a feature request/change on 3CX Ideas : http://www.3cx.com/ideas
