Solved Intercoms that are connected to 3cx
Discussion in '3CX Phone System - General' started by lukehy, Nov 17, 2017.
  1. lukehy
    Nov 17, 2017
    Hello.
    we installed 2 intercoms that have a mini server and every button has a sip (3 buttons in total).
    we added those sips username and password and put an extension from the 3cx.
    the thing is sometimes is works sometimes it dosent (rings the extension),
    the intercom dials but sometimes the extension dosent ring and sometimes we just see a missed call
    the intercoms are Came bpt -Xpi/Eti.
    any idea's ?
  2. nathanmf
    May 29, 2017
    6
    Hey mate,
    Did you get a result here?
    I am interested
  3. StefanW
    Jun 2, 2009
    1,230
    95
  4. lukehy
    Nov 17, 2017
    Hello.
    I resolved it by checking the network that blocked the ports
    it was only open from the checkpoint to one side (any to any)
    for example from the 3cx to the intercom but not from the intercom to the to the 3cx
    the configuration in the end was 2 intercoms 3 buttons that each has its own sip
    now its working perfectly.
    NickD_3CX likes this.
