interconnection of 2 networks for 3CXphone System
Discussion in '3CX Phone System - General' started by coulibaly, Sep 28, 2007.
  1. coulibaly
    Sep 19, 2007
    I have a setup problem. The 3CX phone system is in the Office A with NAT (its ip is 192.168.2.29), I want to connect a soft phone 3CX in my remote office B. The phone cannot registered.
    The NAT server is on Linux.It has a public IP connected to the internet and the second network card has the IP:192.168.2.1
    What can I do for this setup.
    Please help me. Sorry for my english.
    Thanks to all.
    Coulibaly
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi coulibaly,
    Please try to refer to this post to do the port forwarding
    http://www.3cx.com/forums/viewtopic.php?t=1697.
  3. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    So are you using 192.168.2.X for an internal range at both locations?
