Solved Intercoom seems don't work but it is a italian translation problem, please fix it !
Discussion in '3CX Phone System - General' started by tobyto, Mar 19, 2017.
  1. tobyto
    Feb 2, 2017
    11
    i have spent a lot of time to understand why intercom and paging don't working, after i checked english manual and i have see you tell to mark Can Intercom” option in “Rights currently assigned” section.
    the problem is in italian language the translation is done to reverse way "Non è possibile utilizzare la funzione interfono" if flagged italian translation tell "don't use intercom"...
    this is the problem why intercoom was not working...
    I hope this post can change the italian translation.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi tobyto,
    Thank you for your feedback :). We will change this on the next upgrade as we informed by our R&D department.
