intergrate 3cx into microsoft access 2010
Discussion in '3CX Phone System - General' started by liam01752, Jan 5, 2011.
  1. liam01752
    Jan 5, 2011
    We have installed 3cx version 9.0.15770.0 and are having problems getting this to talk to microsoft accesss 2010. I have managed to install the outlook plugin and when the phone rings outlook shows a pop out tag with the phone number in but does not fill in the contact details from the address book.Does anybody no how i can get 3cx to talk to access 2010 to fill out a field on a form with the caller id. Is there a plugin in available for access or does it have to be done through coding.
    thanks Liam
  2. catprotec
    Oct 31, 2010
    Hi There,
    has anyone a solution to connect MS Access to 3CX to notify users of incoming calls and search contacts within Access ?
    Regards,
    Markus
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    There is nothing like this available today. If you add the contacts to the company phonebook than you will get the contact details.
  4. catprotec
    Oct 31, 2010
    Unfortunately that isn't the solution.
    I Search for a possibility to use CRM-Integration with the API to signal an incoming call for the extension witihin
    the ERP-System.
    So that for example a new quote can be created with the contact from the ERP, based on the incoming caller ID
    Scenario:
    - a call is incoming at your phone
    - The call is shown within your ERP-System and if available the attributed contact is shown
    - You can use a button to create a new incident or quote based on the contact from the incoming call
