Intermitant Firewall Failiure
Discussion in '3CX Phone System - General' started by jdennis79, Sep 27, 2008.
  1. jdennis79
    Jun 2, 2008
    5
    Have 3cx and the firewall test will fail 1 in 3 times (roughly) Not sure why. Have been over the Port settings 100 times everything is correct im sure.
    Im using a Draytek 2700, but have tried other difernet kind of routers...still the same
    Im using 3CX Phone System v6.0.806.0 but was doing the same thing on V5
    Using Gama trunk with Demon ADSL ...both beleived to be ok
    When i get Firewall Failiure the port that it fails on is different every time.. heres my latest....
    1 9000 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 62.49.5.142:9000
    2 9000 Information (9) Port is open and can be used for calls. externalAddress = 62.49.5.142:9000
    if i do it again it passes.
    Confused...... if it passes once shouldnt it pass everytime?
    We are experincing dropped cals, and bad quality, all intermitant.
    Any help would be apprciated :)
    thanks
    James
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    TRY another stun server
  3. jdennis79
    Jun 2, 2008
    5
    ok will try.....
    Just a thought.... when a succesful call is made, during the call the quality can deteriorate badly. If it was the stun server problem would this happen?
    JAmes
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    stun server for connect only and not resposable about quality
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,889
    190
    This all points to network level problems - either firewall configuration or the way your ISP is doing NAT...... If the firewall check fails intermittently then there is definitely a problem.
  6. jdennis79
    Jun 2, 2008
    5
    Ok have tried many different routers so im sure its not that.
    My ISP is Demon, is there any known problems with Demon? we are on an 8mb (down) 800k (Up) conection.
    Have tried 3cx on three different PC's and pluged them directly into the router to rule out cabling/infrastructure issues...still the same.
    Its the fact that it intermitant thats so weird!
    thanks
    James
  7. jdennis79
    Jun 2, 2008
    5
    Hi all, This is an old post....but thought i would see if there is any new ideas out there :)
    Have now changed ISP to Freedom2Surf....still getting same problems.
    Really dont undestand whats wrong.
    any help appreciated.
    thanks
    James
