Intermittant Audio Since Upgrade
Discussion in '3CX Phone System - General' started by ehrendreich, May 26, 2011.
  1. ehrendreich
    Sep 21, 2008
    12
    Recently I upgraded to version 10. At first I thought perhaps that it was a port that changed. I ran the firewall checker and it passed. There are some errors in the log but I am not sure what they mean. I have included the log below.
    Code:
    16:29:10.140|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060;transport=TCP]<br>
    16:29:10.171|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(49): Device joined: sip:101@192.168.0.101:5062<br>
    16:29:10.187|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(49): Device joined: sip:9204823418@208.93.226.214:5060<br>
    16:29:19.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:29:51.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:30:23.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:30:55.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:31:27.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:31:59.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:32:31.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:33:03.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:33:35.468|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [49]<br>
    16:33:48.781|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(49): Call is terminated<br>
    17:31:00.312|.\Line.cpp(348)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound out-of-office hours rule (9206529952) for 10000 forwards to DN:800<br>
    17:31:00.328|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(50): Incoming call from 9208603306@(Ln.10000@Broadvox Fusion Registered) to <sip:800@192.168.0.15:5060><br>
    17:31:00.359|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    17:31:00.359|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:800@192.168.0.15:5060><br>
    17:31:00.359|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(50): Route 1: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd]<br>
    17:31:00.390|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(50): Calling Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd]<br>
    17:31:00.625|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(50): Alerting sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd<br>
    17:31:00.625|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:800@127.0.0.1:5060]<br>
    17:31:00.656|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(50): Device joined: sip:9204823418@208.93.226.214:5060<br>
    17:31:00.671|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(50): Device joined: sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd<br>
    17:31:10.687|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(50): Call is terminated<br>
    17:31:40.609|.\Line.cpp(348)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound out-of-office hours rule (9206529952) for 10000 forwards to DN:800<br>
    17:31:40.625|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(51): Incoming call from 7028511360@(Ln.10000@Broadvox Fusion Registered) to <sip:800@192.168.0.15:5060><br>
    17:31:40.656|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    17:31:40.656|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:800@192.168.0.15:5060><br>
    17:31:40.656|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(51): Route 1: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd]<br>
    17:31:40.703|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(51): Calling Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd]<br>
    17:31:40.921|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(51): Alerting sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd<br>
    17:31:40.921|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:800@127.0.0.1:5060]<br>
    17:31:40.953|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(51): Device joined: sip:9204823418@208.93.226.214:5060<br>
    17:31:40.984|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(51): Device joined: sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd<br>
    17:31:51.828|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [51]<br>
    17:32:23.828|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [51]<br>
    17:32:26.953|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(51): Call is terminated<br>
    22:20:29.343|.\Line.cpp(348)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound out-of-office hours rule (9206529952) for 10000 forwards to DN:800<br>
    22:20:29.390|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(52): Incoming call from 9206529398@(Ln.10000@Broadvox Fusion Registered) to <sip:800@192.168.0.15:5060><br>
    22:20:29.406|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    22:20:29.421|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:800@192.168.0.15:5060><br>
    22:20:29.421|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(52): Route 1: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd]<br>
    22:20:29.515|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(52): Calling Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd]<br>
    22:20:29.656|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(52): Alerting sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd<br>
    22:20:29.656|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:800@127.0.0.1:5060]<br>
    22:20:29.687|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(52): Device joined: sip:9204823418@208.93.226.214:5060<br>
    22:20:29.718|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(52): Device joined: sip:800@127.0.0.1:40600;rinstance=19e9d9fb6cb92dcd<br>
    22:20:55.687|.\SLServer.cpp(839)|Log2|MediaServer|MediaServerReporting::DTMFhandler:[MS211000] C:52.1: 208.93.226.214:30712 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.<br>
    22:20:56.406|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [52]<br>
    22:21:00.640|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    22:21:00.640|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:103@127.0.0.1:5060><br>
    22:21:00.656|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(52): Route 1: Ext:Ext.103@[Dev:sip:103@192.168.0.103:5062]<br>
    22:21:00.718|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(52): Calling Ext:Ext.103@[Dev:sip:103@192.168.0.103:5062]<br>
    22:21:01.078|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(52): Alerting sip:103@192.168.0.103:5062<br>
    22:21:01.078|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.103: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:103@192.168.0.15:5060]<br>
    22:21:15.718|.\CallCtrl.cpp(690)|Log2||CallCtrl::onRerouteReq:[CM503005]: Call(52): Forwarding: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5]<br>
    22:21:15.765|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(52): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5]<br>
    22:21:15.781|.\CallLeg.cpp(300)|Log2||CallLeg::onFailure:[CM503003]: Call(52): Call to sip:103@192.168.0.15 has failed; Cause: 487 Request Terminated; from IP:192.168.0.103:5062<br>
    22:21:15.906|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(52): Alerting sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5<br>
    22:21:15.906|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]<br>
    22:21:15.937|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(52): Device joined: sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5<br>
    22:21:26.437|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [52]<br>
    22:21:58.437|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [52]<br>
    22:22:30.437|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [52]<br>
    22:22:58.812|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(52): Call is terminated<br>
    07:58:53.953|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(53): Incoming call from Ext.100 to <sip:3202011@192.168.0.15><br>
    07:58:53.968|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.100: Device info: Device Identified: [Man: Yealink;Mod: T26;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T26P 6.43.0.70] PBX contact: [sip:100@192.168.0.15:5060]<br>
    07:58:53.968|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:3202011@192.168.0.15><br>
    07:58:53.984|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(53): Route 1: VoIPline:9203202011@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    07:58:54.015|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(53): Calling VoIPline:9203202011@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    07:58:54.312|.\CallLeg.cpp(300)|Log2||CallLeg::onFailure:[CM503003]: Call(53): Call to sip:9203202011@208.93.226.214:5060 has failed; Cause: 503 Service Unavailable; from IP:208.93.226.214:5060<br>
    07:58:54.312|.\Call.cpp(1011)|Log2||Call::RouteFailed:[CM503016]: Call(53): Attempt to reach <sip:3202011@192.168.0.15> failed. Reason: Server Failure<br>
    07:58:54.312|.\Call.cpp(567)|Log2||Call::DoEndCall:[CM503020]: Normal call termination. Reason: Server Failure<br>
    07:59:43.656|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(54): Incoming call from Ext.101 to <sip:200@192.168.0.15><br>
    07:59:43.671|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.101: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:101@192.168.0.15:5060]<br>
    07:59:43.671|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:200@192.168.0.15><br>
    07:59:43.671|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(54): Route 1: Ext:Ext.200@[Dev:sip:200@127.0.0.1:5488]<br>
    07:59:43.734|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(54): Calling Ext:Ext.200@[Dev:sip:200@127.0.0.1:5488]<br>
    07:59:43.953|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(54): Alerting sip:200@127.0.0.1:5488<br>
    07:59:43.953|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Dialer for Ext.200] PBX contact: [sip:200@127.0.0.1:5060]<br>
    07:59:44.187|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(55): Incoming call from Ext.200 to <sip:9203740691@paintingpathways.org:5060;nofwd=1><br>
    07:59:44.203|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Dialer for Ext.200] PBX contact: [sip:200@127.0.0.1:5060]<br>
    07:59:44.203|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:9203740691@paintingpathways.org:5060;nofwd=1><br>
    07:59:44.203|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(55): Route 1: VoIPline:9203740691@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    07:59:44.250|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(55): Calling VoIPline:9203740691@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    07:59:45.312|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(55): Alerting sip:9204823418@208.93.226.214:5060<br>
    07:59:45.312|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    07:59:57.671|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(55): Device joined: sip:200@127.0.0.1:5488<br>
    07:59:57.687|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(55): Device joined: sip:9204823418@208.93.226.214:5060<br>
    07:59:57.937|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(54): Device joined: sip:101@192.168.0.101:5062<br>
    07:59:58.093|.\CallLeg.cpp(300)|Log2||CallLeg::onFailure:[CM503003]: Call(54): Call to sip:200@paintingpathways.org has failed; Cause: 487 Request Terminated; from IP:127.0.0.1:5488<br>
    07:59:58.125|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(55): Call is terminated<br>
    08:00:02.359|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(54): Call is terminated<br>
    08:01:22.375|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(56): Incoming call from Ext.101 to <sip:3202011@192.168.0.15><br>
    08:01:22.390|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.101: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:101@192.168.0.15:5060]<br>
    08:01:22.390|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:3202011@192.168.0.15><br>
    08:01:22.390|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(56): Route 1: VoIPline:9203202011@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    08:01:22.437|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(56): Calling VoIPline:9203202011@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    08:01:23.703|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(56): Alerting sip:9204823418@208.93.226.214:5060<br>
    08:01:23.703|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    08:01:26.046|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(56): Device joined: sip:101@192.168.0.101:5062<br>
    08:01:26.062|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(56): Device joined: sip:9204823418@208.93.226.214:5060<br>
    08:01:46.656|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [56]<br>
    08:02:18.656|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [56]<br>
    08:02:25.406|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(56): Call is terminated<br>
    08:04:41.781|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(57): Incoming call from Ext.101 to <sip:3740691@192.168.0.15><br>
    08:04:41.796|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.101: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:101@192.168.0.15:5060]<br>
    08:04:41.796|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:3740691@192.168.0.15><br>
    08:04:41.812|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(57): Route 1: VoIPline:9203740691@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    08:04:41.843|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(57): Calling VoIPline:9203740691@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    08:04:42.890|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(57): Alerting sip:9204823418@208.93.226.214:5060<br>
    08:04:42.890|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    08:04:58.000|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(57): Device joined: sip:101@192.168.0.101:5062<br>
    08:04:58.015|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(57): Device joined: sip:9204823418@208.93.226.214:5060<br>
    08:04:58.656|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [57]<br>
    08:05:03.953|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(57): Call is terminated<br>
    08:16:48.968|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(58): Incoming call from Ext.102 to <sip:999@192.168.0.15><br>
    08:16:49.000|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.102: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:102@192.168.0.15:5060]<br>
    08:16:49.015|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:999@192.168.0.15><br>
    08:16:49.015|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(58): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5]<br>
    08:16:49.078|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(58): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5]<br>
    08:16:49.265|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(58): Alerting sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5<br>
    08:16:49.265|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]<br>
    08:16:49.296|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(58): Device joined: sip:102@192.168.0.102:5062<br>
    08:16:49.312|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(58): Device joined: sip:999@127.0.0.1:40600;rinstance=ef3a99fc58211da5<br>
    08:17:08.875|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [58]<br>
    08:17:40.875|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [58]<br>
    08:18:12.875|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [58]<br>
    08:18:44.875|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [58]<br>
    08:18:49.640|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(58): Call is terminated<br>
    08:50:44.890|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(59): Incoming call from Ext.102 to <sip:6824159@192.168.0.15><br>
    08:50:44.906|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.102: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:102@192.168.0.15:5060]<br>
    08:50:44.921|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:6824159@192.168.0.15><br>
    08:50:44.921|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(59): Route 1: VoIPline:9206824159@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    08:50:44.953|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(59): Calling VoIPline:9206824159@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    08:50:46.437|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(59): Alerting sip:9204823418@208.93.226.214:5060<br>
    08:50:46.437|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    08:50:55.843|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(59): Device joined: sip:102@192.168.0.102:5062<br>
    08:50:55.859|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(59): Device joined: sip:9204823418@208.93.226.214:5060<br>
    08:51:03.781|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [59]<br>
    08:51:35.781|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [59]<br>
    08:52:07.781|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [59]<br>
    08:52:39.781|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [59]<br>
    08:52:42.921|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(59): Call is terminated<br>
    09:09:22.859|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(60): Incoming call from Ext.101 to <sip:5532698@192.168.0.15><br>
    09:09:22.875|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.101: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:101@192.168.0.15:5060]<br>
    09:09:22.890|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:5532698@192.168.0.15><br>
    09:09:22.890|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(60): Route 1: VoIPline:9205532698@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    09:09:22.921|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(60): Calling VoIPline:9205532698@(Ln.10000@Broadvox Fusion Registered)@[Dev:sip:9204823418@208.93.226.214:5060]<br>
    09:09:25.250|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(60): Alerting sip:9204823418@208.93.226.214:5060<br>
    09:09:25.250|.\Line.cpp(1390)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Broadvox Fusion Registered] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9204823418@75.146.156.197:5060]<br>
    09:09:39.500|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(60): Device joined: sip:101@192.168.0.101:5062<br>
    09:09:39.531|.\CallCtrl.cpp(734)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(60): Device joined: sip:9204823418@208.93.226.214:5060<br>
    09:09:41.796|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:10:13.796|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:10:45.796|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:11:17.796|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:11:48.296|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:12:19.156|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:12:50.343|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [60]<br>
    09:13:12.625|.\Call.cpp(1292)|Log2||Call::Terminate:[CM503008]: Call(60): Call is terminated<br>
    09:15:21.484|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(61): Incoming call from Ext.102 to <sip:200@192.168.0.15><br>
    09:15:21.531|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.102: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:102@192.168.0.15:5060]<br>
    09:15:21.531|.\CallCtrl.cpp(419)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:200@192.168.0.15><br>
    09:15:21.531|.\CallCtrl.cpp(559)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(61): Route 1: Ext:Ext.200@[Dev:sip:200@127.0.0.1:5488]<br>
    09:15:21.609|.\Target.cpp(431)|Log2||Target::makeOneInvite:[CM503025]: Call(61): Calling Ext:Ext.200@[Dev:sip:200@127.0.0.1:5488]<br>
    09:15:21.781|.\CallLeg.cpp(289)|Log3||CallLeg::onAnswer:[CM503002]: Call(61): Alerting sip:200@127.0.0.1:5488<br>
    09:15:21.781|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Dialer for Ext.200] PBX contact: [sip:200@127.0.0.1:5060]<br>
    09:15:21.984|.\CallCtrl.cpp(271)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(62): Incoming call from Ext.200 to <sip:9203740691@paintingpathways.org:5060;nofwd=1><br>
    09:15:22.000|.\Extension.cpp(1404)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Dialer for
