Intermittent hold music.
Discussion in '3CX Phone System - General' started by telis, Apr 11, 2017.
  1. telis
    telis New Member
    Aug 13, 2007
    158
    28
    We've just upgraded from v12.5 to v15.
    Our custom hold music is playing intermittently, not poor quality. Sometimes it will play, some times it won't, leaving the caller "listening" to static.
    The .wav file has been correctly re-encoded, 8 KHz, 16 bit, mono. I have played back the hold music though a handset, no problems.
    I had a look though the forums and couldn't see anyone having posted about this.
    Thx.
  2. telis
    telis New Member
    Aug 13, 2007
    158
    28
    as a clarification:
    The issue arises with call queues. The same file is also used as the hold music but the issue is specifically when it's being used as the call queue .wav file.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
  4. telis
    telis New Member
    Aug 13, 2007
    158
    28
    I will try this tonight out of hours but I'm pretty sure it's not a encoding error. I would upload the file here but it's too big for the forum limits.
  5. telis
    telis New Member
    Aug 13, 2007
    158
    28
    This seems to have stopped of it's accord. Strange.
  6. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Glad to hear it is now working. Keep an eye on it and let us know if the issue re-appears
