Internal Call Blocking
Discussion in '3CX Phone System - General' started by yerfdog, Feb 8, 2016.
  1. yerfdog
    Feb 3, 2012
    6
    Hi All,
    I have been trying to work out away of blocking some users from call others.
    We have some people that should not be calling certain people within the system. How can i block them?
    10,570
    247
    If the sets (ATAs) they are using, have internal dialplans, then those plans could be set-up to block certain numbers. Other than that I'm not aware of a way to prevent calls to particular extensions.
    If there are only a few numbers involved, you might make use of Caller ID at the called extension end, to forward the specific caller off to a voicemail box with a recording stating that their call will not go through.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    There is a very simple solution using forward exceptions for certain users, you may specify a list of numbers like 101-125,130 which you don't want to call the user. You may terminate the call (i.e. resulting busy tone) or forward to another extension (i.e. boss-secretary feature). Also this rule can be valid for certain time (office hours for example).
  4. yerfdog
    Feb 3, 2012
    6
    Great,
    Works a treat.
    Mike
