Internal calls Callback on busy (by pressing a specific dial code)
Discussion in 'Ideas' started by echoinformatica, Nov 21, 2016.
Internal calls Callback on busy (by pressing a specific dial code) 5 5 29votes
5/5, 29 votes
  1. echoinformatica
    Aug 8, 2016
    6
    7
    Hi All,
    many traditional PBX have a function that permit a caller to be recalled back automatically by pressing a specific number on the phone keyboard. Can we have this smart function on internal calls in 3CX?
    Thanks for your help!
  2. digiteo
    Mar 22, 2016
    16
    +1 vote
    narkumas likes this.
  3. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    25
    +1 vote
    But please let's have it for external calls too! I have replaced our UNIFY PBX with 3CX and people are moaning because of some missing features.
  4. the123
    Sep 23, 2015
    10
    8
    Our clients are asking for it as well... +1 Vote
  5. jj1
    jj1
    Feb 23, 2012
    24
    Although we use mostly Yealink handsets which support the call completion feature this would be great for use with other handsets. Having it for external calls would also be great, not sure how easy this would be to implement though.
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    25
  7. JackH
    Aug 4, 2017
    7
    How does call completion work exactly? I have enabled it on the phones but when calling a busy extension it still just goes straight to voicemail
  8. that1guy
    Jul 27, 2017
    46
  9. spiegelinstitut
    Oct 19, 2017
  10. VictorSP
    Sep 6, 2016
    61
    12
    +1
  11. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    627
    105
    You could create a call flow designer application that does this for you. You could assign this CFD application to a button on your phone. When pressed, the application would look at the last number you dialed, and start monitoring for when this number was no longer connected to a call. As soon as the other party hangs up, the application could call you back (MakeCall). If you don't answer, because you have walked away from your desk, the other party would not be contacted. This would require a windows service as well as the CFD, but if you need it now, it can be done.
    While this is straightforward to do for internal extensions, I don't see how this would be possible for external phones since the only way to know the other party is off the phone is to call the number repeatedly. That seems infeasible.
  12. Rodrigo Silván
    Feb 16, 2018
  13. Voipdude
    Feb 16, 2018
  14. Daniele Talami
    Dec 29, 2016
  15. Giuseppe_P
    Jan 24, 2018
  16. kenzoo
    Dec 1, 2017
    27
  17. Aleksa
    Mar 12, 2018
    5
    +1 we also need this feature
  18. kenzoo
    Dec 1, 2017
    27
  19. MDigital AG
    Jul 29, 2018
