Internal calls not working
Discussion in '3CX Phone System - General' started by oliverm, Jan 23, 2012.
  1. oliverm
    Mar 10, 2009
    79
    Our 3cx server died so we reinstalled it to a new machine and restored from backups. All very easy.
    However since then our internal calls dont work. This also means that calls coming in from outside dont work as they get directed to a group number, and reaching any internal phones doesnt work. Outgoing calls are fine.
    Incoming calls, when they aren't answered within 10 seconds, are redirected to an answering service and that mechanism works fine.
    In the logs we get "request timeout; internal" whenever we try to dial an internal extension.
    We can ping the phones from the 3cx server and view the web interfaces of the phones without any issue. The phones themselves register with 3cx and show as being there and with a green icon. Each phone can make outgoing calls without any issue. However the 3cx server is unable to direct any calls to the extensions.
    Any ideas?
    Olly
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    "Incoming calls, when they aren't answered within 10 seconds, are redirected to an answering service and that mechanism works fine." - this means that your phones are ringing and if you pick-up you don't get any audio?
    Try to get a whireshark capture to see whats happening and why you get a timeout. Capture packets between a phone and your PBX for an incoming call that does not work and an outgoing one that work and maybe you will find the problem.
  3. oliverm
    Mar 10, 2009
    79
    The phones dont ring. The connection from the 3cx server to the phones effectively times out and it then gets forwarded to the answering service.
    If you call another internal phone you get no ring tone at either end.
    Olly
