internal calls won't work
Discussion in '3CX Phone System - General' started by shark95763, Aug 24, 2007.
  1. shark95763
    Aug 22, 2007
    22
    I got 2 ext setup 100 and 101
    look at the log: on both softphones i get 403 forbidden
    23:35:40.468 CallConf::Rejected [CM103005] Call(23) is rejected: This line disallows incoming calls
    23:35:40.468 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.2.1'; From: '101'; To: '100'; Rline: '100'; Contact: '101'
    23:35:33.037 CallConf::Rejected [CM103005] Call(22) is rejected: This line disallows incoming calls
    23:35:33.037 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.2.101'; From: '100'; To: '101'; Rline: '101'; Contact: '100'
    23:35:08.001 CallConf::Rejected [CM103005] Call(21) is rejected: This line disallows incoming calls
    23:35:08.001 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.2.101'; From: '100'; To: '101'; Rline: '101'; Contact: '100'
    at the moment i got no lines setup.... hmmm
  2. gbarnes
    Aug 3, 2007
    83
    Softphones
    What softphones are you using?
    Do you have STUN enabled on your softphone, if you are on an internal network then DO NOT USE STUN, as it will give your external IP address.
    See if that works, also, are your extensions registered (ie green icon on status page)?
    Hope you get it soon..
    Graeme.
