Internal Calls
Discussion in '3CX Phone System - General' started by Anonymous, Oct 3, 2006.
  1. Anonymous
    Anonymous Guest
    Hi everybody
    I am a begginer with 3cx server, and I configured two extension.
    100 and 101.
    I am using the 3cx Software, but I can
  2. Anonymous
    Anonymous Guest
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    Means calling phone is not registered
    When you receive that error, it means the phone from which you are calling is not registered with the system. Check the server status log for the exact caller and callee - checking the SIP id should show that somehow the phone is not sending the correct information or the PBX does not have the extension configured correctly.
    As a side note, we are releasing a new build over the next few days (by 7 october) that will have better error logging in the server status window.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
