Internal contact on 3CXPhone
Discussion in 'iOS' started by alexgosset, Apr 16, 2013.
  1. alexgosset
    Apr 16, 2013
    6
    Hi all,
    Is it possible to have access to the internal directory from the 3CX Phone on iOS ? I've searched, and don't find it :(
    Thanks in advance.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @alexgosset
    The 3CX iOS app has access to all the contacts on the iOS device. Are you by any chance referring to the 3CX Phone System "Company Directory"?
  3. alexgosset
    Apr 16, 2013
    6
    @ Kevin :
    Yes, indeed, I'm referring to the Company Phonebook, AND I would like to have too the list (if possible) of my internal Extensions.
    Alexandre
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    @alexgosset
    This is effectively a feature request: https://apps.facebook.com/threecxideas/
  5. alexgosset
    Apr 16, 2013
    6
    Thanks Kevin, I'll do it.
  6. StefanW
    Jun 2, 2009
    1,222
    93
    3cxphone 12 has it, company and private along with ur phone book of the device
  7. alexgosset
    Apr 16, 2013
    6
    Thanks Stefan !
