danhriscanu said:Hi,
Indeed there is an issue with IIS on Windows Server 2012. We are looking into it right now and it will be fixed in the future. Meanwhile please use Abyss on that operating system.
mixig said:danhriscanu said:Hi,
Ok, thanks for the info...
StefanW said:Can someone with server 2012 and SP2 check is now everything ok?
From blog:This service pack fixes several issues and also adds new features such as support for Windows 8, Windows Server 2012
nickybrg said:A clean full install is required.
Reason - when a software is released BEFORE an operating system release, this means that the software installation COULD NOT be tested on the final version of the operating system that was released. This is logical.
So make it a point in the future - even with other applications, that before the company officially releases support for the new OS, do not try installing a version that was released before.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
