internal extensions SOMETIMES no audio
Discussion in '3CX Phone System - General' started by DaKhalli, Jun 28, 2007.
  1. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    Hi there yall,
    I have a fresh installation of 3cx running, all worked perfectly for bout 2 days, all external calls go fine without any problems. (good audio, everything fine)
    But internal theres problems:
    the phone rings at reception, she picks up, puts caller on hold, and trys to call an extension to transfer the call too. the extension beeing called answeres the call but heares nothing, also the receptionist hears nothing.
    this does not happen all the time, but enough times to be annoying.
    Also calls between extension without someone waiting have that problem
    sometimes.
    And the receptionist asked me if there was a way she could transfer a customer to an extension and let it ring as long as she wants (now she gets it back automatically afther three rings or so) and pick it back when she wants if no answer?
    We use a dedicated server for 3cx, a mix of sulptura and grandstream phones.
    hope to have a solution soon :D
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We sure need more info to help this. Guess, what happens if I call MS support and ask them to help, because "Sometimes my system hangs up"
  3. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    well i cant really pinpoint where the problem may be, we use sulptura ata and grandstream 2000 devices. all registers perfectly, all are bound to media server and unchecked support for re-invite in the voip gateway config (else music on hold is buggered)
    If the receptionist dials an extension, she hears ringing when the other side picked up the line. The other line hears nothing.
    part of server log:
    Time Function Message
    12:04:05.578 ListenConnect [CM114000] SL: connected viop-srv-01:0/PHPExtension_0 at [viop-srv-01:0]/PHPExtension_0
    11:15:06.937 StratLink::eek:nHangUp [CM104001] Call(18): Ln:10001@Voiceworks Notom hung up call; cause: BYE; from IP:213.239.164.175
    11:14:50.812 MediaServerReporting::DTMFhandler [MS211000] Call(18) Ln:10001@Voiceworks Notom: DTMF (in-band) from 213.239.164.176:10186 detected.
    11:10:53.125 MediaServerReporting::DTMFhandler [MS211000] Call(20) Ext.770: DTMF (in-band) from 10.10.1.44:16406 detected.
    11:03:01.328 StratLink::eek:nHangUp [CM104001] Call(21): Ln:10001@Voiceworks Notom hung up call; cause: BYE; from IP:213.239.164.175
    11:02:45.140 MediaServerReporting::RTPSender [MS004000] Call(21) Ext.110: (ACTIVE): Can't send RTP stream to 0.0.0.0:5004 destination unreachable
    11:02:42.953 CallLegImpl::eek:nConnected [CM103001] Call(21): Created audio channel for Ext.110 (10.10.1.41:5004) with Media Server (10.10.1.12:7062)
    11:02:42.937 StratInOut::eek:nConnected [CM104005] Call(21): Setup completed for call from Ln:10001@Voiceworks Notom to Ext.110
    11:02:42.937 CallLegImpl::eek:nConnected [CM103001] Call(21): Created audio channel for Ln:10001@Voiceworks Notom (213.239.164.176:17512) with Media Server (84.107.147.253:9002)
    11:02:40.718 CallConf::eek:nProvisional [CM103003] Call(21): Ext.110 is ringing
    11:02:40.593 CallConf::eek:nIncoming [CM103002] Call(21): Incoming call from 0652036146 (Ln:10001@Voiceworks Notom) to sip:wsprx01.0237111916@213.239.164.175:5080
    11:02:32.750 StratLink::eek:nHangUp [CM004001] Call(18): HangUp from wrong leg has arrived. Leg will be removed from call
    11:02:25.656 CallLegImpl::eek:nConnected [CM103001] Call(18): Created audio channel for Ext.770 (10.10.1.44:16406) with Media Server (10.10.1.12:7058)
    11:02:25.656 StratTransfer::finishTransfer [CM108005] Call(18): Transfer finished, Ln:10001@Voiceworks Notom is connected to Ext.770
    11:02:25.656 StratTransfer::eek:nConnected [CM008008] Call(18): Transfer: wrong leg is connected
    11:02:25.625 StratLink::Transfer [CM104002] Call(18): transfers Ln:10001@Voiceworks Notom from Ext.110 to sip:770@10.10.1.12
    11:02:21.437 CallLegImpl::eek:nConnected [CM103001] Call(20): Created audio channel for Ext.770 (10.10.1.44:16406) with Media Server (10.10.1.12:7058)
    11:02:21.421 StratInOut::eek:nConnected [CM104005] Call(20): Setup completed for call from Ext.110 to Ext.770
    11:02:21.421 CallLegImpl::eek:nConnected [CM103001] Call(20): Created audio channel for Ext.110 (10.10.1.41:5006) with Media Server (10.10.1.12:7056)
    11:02:08.765 CallConf::eek:nProvisional [CM103003] Call(20): Ext.770 is ringing
    11:02:08.656 CallConf::eek:nIncoming [CM103002] Call(20): Incoming call from 110 (Ext.110) to sip:770@10.10.1.12
    11:02:06.515 MediaServerReporting::RTPSender [MS004000] Call(18) Ext.110: (ACTIVE): Can't send RTP stream to 0.0.0.0:5004 destination unreachable
    11:01:35.609 MediaServerReporting::RTPSender [MS104000] Call(18) Ext.110: (ACTIVE) RTP stream to 10.10.1.41:5004 restored.
    11:01:35.578 StratInOut::eek:nHangUp [CM104007] Call(19): Call from Ext.110 to 110 has been terminated by Ext.110; cause: CANCEL; from IP:10.10.1.41
    11:01:16.156 CallConf::eek:nProvisional [CM103003] Call(19): Ext.770 is ringing
    11:01:16.031 CallConf::eek:nIncoming [CM103002] Call(19): Incoming call from 110 (Ext.110) to sip:770@10.10.1.12
    11:01:13.171 MediaServerReporting::RTPSender [MS004000] Call(18) Ext.110: (ACTIVE): Can't send RTP stream to 0.0.0.0:5004 destination unreachable
    11:00:18.484 CallLegImpl::eek:nConnected [CM103001] Call(18): Created audio channel for Ext.110 (10.10.1.41:5004) with Media Server (10.10.1.12:7048)
    11:00:18.453 StratInOut::eek:nConnected [CM104005] Call(18): Setup completed for call from Ln:10001@Voiceworks Notom to Ext.110
    11:00:18.453 CallLegImpl::eek:nConnected [CM103001] Call(18): Created audio channel for Ln:10001@Voiceworks Notom (213.239.164.176:10186) with Media Server (84.107.147.253:9000)
    11:00:15.437 CallConf::eek:nProvisional [CM103003] Call(18): Ext.110 is ringing
    11:00:15.328 CallConf::eek:nIncoming [CM103002] Call(18): Incoming call from 0646005458 (Ln:10001@Voiceworks Notom) to sip:wsprx01.0237111916@213.239.164.175:5080
    10:58:09.218 StratLink::eek:nHangUp [CM104001] Call(17): Ln:10000@Gorree Voiceworks hung up call; cause: BYE; from IP:213.239.164.175
    10:56:17.218 CallLegImpl::eek:nConnected [CM103001] Call(17): Created audio channel for Ext.740 (10.10.1.50:16416) with Media Server (10.10.1.12:7046)
    10:56:17.187 StratInOut::eek:nConnected [CM104005] Call(17): Setup completed for call from Ln:10000@Gorree Voiceworks to Ext.740
    10:56:17.171 CallLegImpl::eek:nConnected [CM103001] Call(17): Created audio channel for Ln:10000@Gorree Voiceworks (213.239.164.176:15240) with Media Server (84.107.147.253:9002)
    10:56:02.375 CallConf::eek:nProvisional [CM103003] Call(17): Ext.740 is ringing
    10:56:02.234 CallConf::eek:nIncoming [CM103002] Call(17): Incoming call from 0 (Ln:10000@Gorree Voiceworks) to sip:gorree01@213.239.164.175:5080
    10:51:36.125 StratLink::eek:nHangUp [CM104001] Call(16): Ln:10001@Voiceworks Notom hung up call; cause: BYE; from IP:213.239.164.175
    10:48:29.218 CallLegImpl::eek:nConnected [CM103001] Call(16): Created audio channel for Ext.110 (10.10.1.41:5004) with Media Server (10.10.1.12:7044)
    10:48:29.171 StratInOut::eek:nConnected [CM104005] Call(16): Setup completed for call from Ln:10001@Voiceworks Notom to Ext.110
    10:48:29.171 CallLegImpl::eek:nConnected [CM103001] Call(16): Created audio channel for Ln:10001@Voiceworks Notom (213.239.164.176:15994) with Media Server (84.107.147.253:9000)
    10:48:20.562 CallConf::eek:nProvisional [CM103003] Call(16): Ext.110 is ringing
  4. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    i posted a big chunk from the server status log, since i cannot reproduce the problem, it occurs random.
  5. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
  6. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Hi Dakhalli
    Did you resolve your issue? could you restart all PBX services, immediately try and recreate the problem only and then sending the logs in the post?
    In the logs there was a note - Cant send RTP stream - dest unreachable - are the phones configured correctly? nik
  7. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    hey nick yeh sorry for not following up on the post.
    Seemed the problem only existed with 2 ata's. When i rebooted them, all worked fine.
    The the error sometimes still pops up (can't send rdp stream) is all seems to work perfectly.
    And again, sorry for not following up :D
  8. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    No probs - the important thing is that everything is working fine.
    Nik
