Internal / external calls
Discussion in '3CX Phone System - General' started by voipbaennjer, Jul 15, 2009.
  1. voipbaennjer
    Jul 10, 2009
    44
    Does it force any problems when I'm dialing external calls without a prefix?
    I've setup my 3CX with 3 digit extensions and no prefix for outgoing calls, I only specify the extensions that can use a particular line in that outbound rule.
    So far I have no difficulties.
    Any comments or suggestions?
  2. ec268
    Apr 18, 2009
    22
    We never set prefix for external call since first installion, it almost 3 years. No problem so far ~
  3. wzaatar
    Aug 1, 2007
    90
    Agree and confirm. No need to make any special configuration. 3CX works flawlessly.
  4. voipbaennjer
    Jul 10, 2009
    44
    As a telephone service technician I grew up with "old fashioned" PBXs (first relay switched then electronic systems later ISDN), sometimes up to 4096 ports. But all of them needed a prefix to seize an outgoing line.
    That's why I'm a bit surprised 3CX works without. Which is fine, because if in the past someone wanted tu use one of our phones you allways had to tell him "dial 0 to get an outgoing line".
    Now this times are gone thanks to 3CX.
  5. leejor
    11,126
    330
    I guess it would depend on whether there was a conflict between outside numbers and internal extensions or voice mail access. If you lived in a region, say North America, and you lived in an area with a couple of area codes, say 360 and 206, AND all outside local numbers required 10 digit dialling, then, unless you had an extension that was 360 or 206, you'd be OK. In some countries, all outside numbers start with a "0", probably no problem. If you lived in an area where you could dial 7 digit local numbers then there is a possibility of a NXX / extension conflict.
    Some people have a POTS line (or multiple) and a VoIP provider (or two) and so want to be able to direct calls using an 9 or 8 as a prefix/access digit.
  6. wzaatar
    Aug 1, 2007
    90
    In that case, I'd guess he could use the number length as an extra constraint so that dialing rules apply.
  7. voipbaennjer
    Jul 10, 2009
    44
    My 3-digit extensions start with 200 because there are 2 3-digit outside numbers (110 and 112 for emergency). All other local and long distance numbers are longer then 3 digits.
    I tested the case that a local number and an extension began with the same digits (ext. 735 and local number 735xxx).
    It worked, I could reach both the extension and the outbound number depending on what number would have been dialed.
  8. wzaatar
    Aug 1, 2007
    90
    Effectively,
    There should not be any issues.
    Glad things are working fine for you ;)
    W.
