Internal lines over internet
Discussion in '3CX Phone System - General' started by rorygennaro, Nov 13, 2007.
  1. rorygennaro
    Nov 7, 2007
    11
    I have 3cx installed on windows 2003 server. If the internal phones are inbound there arent problems. But If I connect in outbond (over internet) i do not ear nothing .
    I have tried with x-lite.
    Es: server is xxxxxx.dyndns.org and the ports are all open
    the client is
    Display Name: 101
    User Name: 101
    Password: correct password for 101
    domain: xxxxxx.dyndns.org
    stun server: stun.3cx.com
    Where a wrong ?
    When I call from client external o internal line I ear but the destinatary do not ear me.
  2. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Include a portion of your status log (make sure its in debug) that covers one of these calls. This will give us an idea of whats going on.
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    488
    On that extension do you have it set as External. Last section under Options.
  4. rorygennaro
    Nov 7, 2007
    11
    Ok, i just click on external to the extencion out of the net and calling to the external line I speak but do not ear and the remote phone ear but not speak.
  5. rorygennaro
    Nov 7, 2007
    11
    00:21:50.500 StratLink::eek:nHangUp [CM104001] Call(1): Ext.101 hung up call; cause: BYE; reason: SIP;description="User Hung Up"
    00:21:28.500 MediaServerReporting::RTPSender [MS104000] Call(1) Ext.101: (ACTIVE) RTP stream to 192.168.0.2:59878 restored.
    00:21:23.968 MediaServerReporting::RTPSender [MS004000] Call(1) Ext.101: (ACTIVE): Can't send RTP stream to 0.0.0.0:59878 destination unreachable
    00:21:21.890 CallLegImpl::eek:nConnected [CM103001] Call(1): Created audio channel for Ln:10001@Wooow (83.211.223.199:61526) with Media Server (85.20.109.145:9002)
    00:21:21.859 StratInOut::eek:nConnected [CM104005] Call(1): Setup completed for call from Ext.101 to Ln:10001@Wooow
    00:21:21.859 CallLegImpl::eek:nConnected [CM103001] Call(1): Created audio channel for Ext.101 (192.168.0.2:59878) with Media Server (85.20.109.145:9000)
    00:21:20.703 CallConf::eek:nProvisional [CM103003] Call(1): Ln:10001@Wooow is ringing
    00:21:17.234 CallConf::eek:nIncoming [CM103002] Call(1): Incoming call from 101 (Ext.101) to sip:0923944148@rorypbx.dyndns.org
    00:20:24.125 ListenConnect [CM114000] SL: connected server:0/PHPExtension_0 at [server]/PHPExtension_0
    00:20:08.937 ServRegs::eek:nAdd [CM113002] Registered: Ext.101
    00:20:08.046 ServRegs::eek:nAdd [CM113002] Registered: Ext.101
    00:18:35.984 ListenConnect [CM114000] SL: connected server:0/VoiceBoxManagerService at [server]/VoiceBoxManagerService
    00:18:34.531 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    00:18:34.531 ClientRegs::eek:nFailure [CM113006] Registration of sip:09231877235@voip.eutelia.it has failed; reason=Service Unavailable
    00:18:34.437 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    00:18:34.437 ClientRegs::eek:nFailure [CM113006] Registration of sip:09231877245@voip.eutelia.it has failed; reason=Service Unavailable
    00:18:34.406 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    00:18:34.406 ClientRegs::eek:nFailure [CM113006] Registration of sip:09231877235@voip.eutelia.it has failed; reason=Service Unavailable
    00:18:34.375 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    00:18:34.375 ClientRegs::eek:nFailure [CM113006] Registration of sip:09231877245@voip.eutelia.it has failed; reason=Service Unavailable
    00:18:33.843 ExtLine::Register [CM110004] Send registration for "09231877245"<sip:09231877235@voip.eutelia.it>
    00:18:33.843 ExtLine::Register [CM110001] Use External IP for device line registration DN='10001' device='Wooow'
    00:18:33.828 ExtLine::Register [CM110004] Send registration for <sip:09231877245@voip.eutelia.it>
    00:18:33.828 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='Eutelia'
    00:18:33.812 ExtLine::Register [CM110004] Send registration for "09231877245"<sip:09231877235@voip.eutelia.it>
    00:18:33.812 ExtLine::Register [CM110001] Use External IP for device line registration DN='10001' device='Wooow'
    00:18:33.765 ExtLine::Register [CM110004] Send registration for <sip:09231877245@voip.eutelia.it>
    00:18:33.765 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='Eutelia'
    00:18:33.531 StunClient::process [CM115002] STUN resolved external IP=85.20.109.145:5060 by server 64.69.76.23
    00:18:33.031 StunClient::process [CM115002] STUN resolved external IP=85.20.109.145:5060 by server 64.69.76.23
    00:18:32.750 MediaServerConnected [CM112000] Media Server is connected
    00:18:32.750 ListenConnect [CM114000] SL: connected server:0/MediaServer at [server]/MediaServer
    00:18:32.734 StunClient::process [CM115001] Send initial STUN request to 64.69.76.23
    00:18:32.703 IVRConnected [CM111000] IVR Server is connected
    00:18:32.703 ListenConnect [CM114000] SL: connected server:5483/IVRServer at [server]/IVRServer
    00:18:32.625 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
    00:18:32.093 CallMgr::DumThread::thread [CM100004] ** Enter DUM Thread **
    00:18:32.046 DBA [CM109000] ** Database connection Ok **
    00:18:32.031 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
    00:18:31.984 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
    00:18:31.984 CallMgr::Initialize [CM100002] Default Local IP address: 192.168.1.1:5060
    00:18:31.828 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
    00:18:31.828 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
    00:18:31.812 LoadLicenceInfo [CM100008] Licence loading error
  6. rorygennaro
    Nov 7, 2007
    11
    As you ca see it says RTP Stream unreachable
    What is it ?
  7. Henk
    Henk Member
    Nov 13, 2007
    250
    RTP, usually that is due to firewall or NAT (you need a Stun server).
    You have a stun server from 3cx, make sure that one is up and running.
