ZacSC
- Joined
- Jan 21, 2016
- Messages
- 34
- Reaction score
- 2
I wanted to know if anyone has seen this issue. I am working to get 3cx setup to test the system to decide if we want to move forward with it as a solution. I have everything working internally and have started setting up the items needed to use the system outside of our network. It seems like its working (minus presence, which I am not sure why thats not working but calls work) but when I run the firewall checker it fails (even though the ports are open and NAT is setup). Some of the ports pass but most fail and look like this...
Testing External Audio RTP Port 9245 using STUN server: stun.3cx.com:3478
Resolving STUN server stun.3cx.com ... Resolved to: [198.50.247.220]
[Test1] Reachability test ... FAILED.
Internal port number (9245) does not match external port number (44317)
Testing External Audio RTP Port 9246 using STUN server: stun.3cx.com:3478
Internal port number (9246) does not match external port number (20766)
Testing External Audio RTP Port 9247 using STUN server: stun.3cx.com:3478
Internal port number (9247) does not match external port number (42783)
Testing External Audio RTP Port 9248 using STUN server: stun.3cx.com:3478
Internal port number (9248) does not match external port number (27424)
Testing External Audio RTP Port 9249 using STUN server: stun.3cx.com:3478
Internal port number (9249) does not match external port number (29473)
I am using the 3CX v14 with all of the updates installed and the 3cx computer and mobile apps.
Any ideas? Does it matter?
