Internal Provisioning IP Incorrect in config file
Discussion in '3CX Phone System - General' started by zar1, Sep 11, 2013.
  1. zar1
    Sep 11, 2013
    When I send a welcome email the provisioning config file attachment has an incorrect IP for the PBX, I've checked in the Phone Provisioning section of Setting in the console and it has the correct, if I change the external address and the resend the welcome email the external IP changes but changing the internal IP has no effect.
    Thanks,
    Michael
