Internal Server Error(500) - New SIP Trunk
Discussion in '3CX Phone System - General' started by Key4ce, Aug 5, 2016.
  1. Key4ce
    Aug 5, 2016
    I have just made a totally fresh install of 3CX v15.0.57336.0 with a pro license but I appear to be having a issue adding a 2nd SIP Trunk.
    When adding a new SIP Trunk i get a Internal Server Error(500) on the server with the following text
    I have noticed there is also a new PostgreSQL event in the Windows event log at the same time with the following:
    I am fine to remove and add another sip trunk but it appears to be the 2nd which is causing the issue. I did set the Activity Log to Verbose but it didn't appear to log anything about this error.
    Hope somebody is able to help.
    Key4ce
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Are the parameters of the two trunks different with regard to the credentials and numbers? The error message indicates that there is a duplicate value when it apparently wants a unique entry. It seems to indicate the AuthID is at fault.
