Internal Server Error(500) when running Firewall Check
Discussion in '3CX Phone System - General' started by JimbobNZ, Dec 4, 2016.
  1. JimbobNZ
    Dec 2, 2016
    13
    3CX: 15.0.59381.0
    OS: Linux 3cx 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
    Code:
    3CX: 15.0.59381.0
    IniParser.Exceptions.ParsingException: Duplicated key 'MS_LOGLEVEL' found in section 'MSSettingsCache while parsing line number 0 with value '' - IniParser version: 2.2.2.0 while parsing line number 28 with value 'MS_LOGLEVEL = PT_INT32,2' - IniParser version: 2.2.2.0 ---> IniParser.Exceptions.ParsingException: Duplicated key 'MS_LOGLEVEL' found in section 'MSSettingsCache while parsing line number 0 with value '' - IniParser version: 2.2.2.0
       at IniParser.Parser.IniDataParser.HandleDuplicatedKeyInCollection(String key, String value, KeyDataCollection keyDataCollection, String sectionName)
       at IniParser.Parser.IniDataParser.AddKeyToKeyValueCollection(String key, String value, KeyDataCollection keyDataCollection, String sectionName)
       at IniParser.Parser.IniDataParser.Parse(String iniDataString)
       --- End of inner exception stack trace ---
       at IniParser.FileIniDataParser.ReadFile(Stream fs, Encoding fileEncoding)
       at ManagementConsoleJS.Services.FirewallChecker.LoadMediaConfig(PhoneSystem root, ApplicationConfiguration appConfig)
       at ManagementConsoleJS.Services.FirewallChecker.LoadConfig(ApplicationConfiguration appConfig)
       at ManagementConsoleJS.Services.FirewallService.Start()
       at lambda_method(Closure , Object , Object[] )
       at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__28.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
       at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__18.MoveNext()
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
       at Microsoft.AspNetCore.Builder.RouterMiddleware.d__4.MoveNext()
       at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.d__3.MoveNext()
