Internal Server Error 500
Discussion in '3CX Phone System - General' started by dscp46, Jun 27, 2016.
  1. dscp46
    Jun 27, 2016
    Running v15.0.0, when I click on "Extensions" and then select an extension to manage. I am getting an Internal Server Error 500. Do you have any thoughts? I've restarted all the services and that did not remedy the issue.
    The error detail log shows;
    System.IO.FileNotFoundException: Could not find file 'C:\ProgramData\3CX\Instance1\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB\SetInfo.xml'.
    File name: 'C:\ProgramData\3CX\Instance1\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB\SetInfo.xml'
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
    at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials, IWebProxy proxy, RequestCachePolicy cachePolicy)
    at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
    at System.Xml.XmlTextReaderImpl.FinishInitUriString()
    at System.Xml.XmlReaderSettings.CreateReader(String inputUri, XmlParserContext inputContext)
    at System.Xml.Linq.XDocument.Load(String uri, LoadOptions options)
    at ConfigurationManagementModel.CfgPromptSet.Serialize_BeforeSerialize(Object sender, SerializeEventArgs e)
    at ConfigurationManagementModel.PropertySerializer.Serialize(ICfgItemInternal cfgItem, SerializeParameters serializeParameters)
    at ConfigurationManagementModel.CfgItemBase.Load()
    at ConfigurationManagementModel.CfgItemManager.GetItem(Object hint)
    at ConfigurationManagementModel.CfgCollectionBase..ctor(ICfgItemManager itemManager, Func`2 filter)
    at ConfigurationManagementModel.PSCfgCollection..ctor(ICfgItemManager itemManager)
    at ConfigurationManagementModel.CfgRoot.CollectionConstructor.Create()
    at System.Lazy`1.CreateValue()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
    at System.Lazy`1.get_Value()
    at ConfigurationManagementModel.CfgCollectionProperty.ConnectToEvents()
    at ConfigurationManagementModel.CfgCollectionProperty.get_Value()
    at ConfigurationManagementModel.CfgRoot.get_PromptSets()
    at ConfigurationManagementModel.CfgExtensionEditor.<InitializeAccessibilities>b__256_17()
    at ConfigurationManagementModel.PropertyAccessibility.GetPropertyAccessibility(ICfgProperty property)
    at ConfigurationManagementModel.CfgItemBase.CheckAccessibilities()
    at ConfigurationManagementModel.CfgItemBase.Initialize()
    at ConfigurationManagementModel.CfgExtensionEditor.Initialize(ICfgItemManager manager)
    at ManagementConsoleJS.Controllers.ExtensionListController.Set(SetEditorPhoneSystemArg arg)
    at Microsoft.AspNet.Mvc.Controllers.ControllerActionExecutor.ExecuteAsync(MethodInfo actionMethodInfo, Object instance, Object[] orderedActionArguments)
    at Microsoft.AspNet.Mvc.Controllers.ControllerActionInvoker.<InvokeActionAsync>d__6.MoveNext()
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at Microsoft.AspNet.Mvc.Controllers.FilterActionInvoker.<InvokeActionFilterAsync>d__53.MoveNext()
    at Microsoft.AspNet.Mvc.Controllers.FilterActionInvoker.<InvokeAsync>d__44.MoveNext()
    at Microsoft.AspNet.Mvc.Infrastructure.MvcRouteHandler.<RouteAsync>d__6.MoveNext()
    at Microsoft.AspNet.Mvc.Routing.InnerAttributeRoute.<RouteAsync>d__10.MoveNext()
    at Microsoft.AspNet.Routing.RouteCollection.<RouteAsync>d__9.MoveNext()
    at Microsoft.AspNet.Builder.RouterMiddleware.<Invoke>d__4.MoveNext()
    at ManagementConsoleJS.Middleware.AuthorizeCorrectlyMiddleware.<Invoke>d__2.MoveNext()
    at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.<Invoke>d__3.MoveNext()
    Ok
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    I saw this sometimes in v14 and the extension was corrupt somehow. I had to delete and recreate.
    Perhaps the devs have more on this.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    From the exception you provided, seems that Prompt 210986B-9412-497f-AD77-3A554F4A9BDB has missing SetInfo.xml.
    Did you perhaps restored a backup to cause this?
    If so update to RC2 and if problem still persist PM and we will look into it!
