Internal server error when clicking Update [solved]
Discussion in '3CX Phone System - General' started by prd1, Jul 11, 2016.
  1. prd1
    Mar 22, 2013
    3cx Ver. : v15, Build 56008
    SO : Windows server 2012 R2
    When i click update button in main dashboard i receive this error :
    Internal Server Error(500)
    System.FormatException: Formato della stringa di input non corretto.
    in System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
    in System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
    in ManagementConsoleJS.VersionStringComparer.CompareStatic(String x, String y)
    in ManagementConsoleJS.Firmware.get_OutOfDate()
    in ManagementConsoleJS.UpdateService.UpdateNotification(IEnumerable`1 list)
    in ManagementConsoleJS.UpdateService.<BuildListForUpdateAsync>d__15.MoveNext()
    --- Fine traccia dello stack da posizione precedente dove è stata generata l'eccezione ---
    in System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    in System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    in ManagementConsoleJS.Controllers.UpdateCheckerController.<CheckForUpdates>d__4.MoveNext()
    in Microsoft.AspNetCore.Mvc.Internal.ObjectMethodExecutor.<CastToObject>d__40`1.MoveNext()
    in Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeActionFilterAsync>d__28.MoveNext()
    in Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeAsync>d__18.MoveNext()
    in Microsoft.AspNetCore.Builder.RouterMiddleware.<Invoke>d__4.MoveNext()
    in ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.<Invoke>d__3.MoveNext()
  2. roadwings
    May 16, 2015
    49
    14
    Re: Internal server error when clicking Update
    I get that too. On the official version of v15.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Could you please try again now please?
    Let me know
  4. prd1
    Mar 22, 2013
    Ok problem solved. thank you
  5. travstoll
    Jul 11, 2016
    11
    Not for me, same issue.
  6. dvanegue
    Feb 8, 2009
    same problem for me
  7. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    @dvanegue I sent a pm get back to me when you see it.
  8. kyagc
    Jul 13, 2016
    9
    I'm having the same issue as well. It says system is up to date, but when you go to updates it gives the internal server error.
    System.FormatException: Input string was not in a correct format.
    at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
    at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
    at ManagementConsoleJS.VersionStringComparer.CompareStatic(String x, String y)
    at ManagementConsoleJS.Firmware.get_OutOfDate()
    at ManagementConsoleJS.UpdateService.UpdateNotification(IEnumerable`1 list)
    at ManagementConsoleJS.UpdateService.<BuildListForUpdateAsync>d__15.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at ManagementConsoleJS.Controllers.UpdateCheckerController.<CheckForUpdates>d__4.MoveNext()
    at Microsoft.AspNetCore.Mvc.Internal.ObjectMethodExecutor.<CastToObject>d__40`1.MoveNext()
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeActionFilterAsync>d__28.MoveNext()
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeAsync>d__18.MoveNext()
    at Microsoft.AspNetCore.Builder.RouterMiddleware.<Invoke>d__4.MoveNext()
    at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.<Invoke>d__3.MoveNext()
  9. 3cxoleg
    3cxoleg Support Team
    Apr 13, 2016
    16
    Hello there,
    on the server where V15 is installed >>
    1. C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\2r7xxxxxxxx\firmware_new
    2. Remove “firmwares.json” file
    3. Restart all 3CX Services and nginx service (or restart the whole server).
    this should solve your issue
  10. ngarner
    Sep 24, 2015
    Thanks very much for that, solved for me as well
  11. lanspeed
    Mar 22, 2016
    Tried this and still getting this error, anyone else having this?
