Internal server error while adding a VoIP line
Discussion in '3CX Phone System - General' started by xc99tour, Mar 12, 2007.
  1. xc99tour
    Jan 2, 2007
    37
    Whist trying to add a VoIP line, I received the following error:
    Cannot save External Line object: ERROR: null value in column "fkiddn" violates not-null constraint
    #0 D:\Program Files\3CX PhoneSystem\Data\Http\functions\fExternalLine.php(91): safeExec(Object(PDOStatement), 'Cannot save Ext...')
    #1 D:\Program Files\3CX PhoneSystem\Data\Http\gateway_lines_upd.php(449): fExternalLine::save(Object(oExternalLine))
    #2 {main}
    Tried is a second time, and it worked fine.
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Strange, thanks for the heads up. Do let us know if you ever run into anything similar again in the future.
