Internal Server Error
Discussion in '3CX Phone System - General' started by oliverm, Jun 3, 2010.
  1. oliverm
    Mar 10, 2009
    79
    Every now and again, our phones refuse to complete a call and show "SERVER INTERNAL ERROR: 9" and give us a noise just like a busy tone. The 3cx logs show;
    16:33:06.062 [CM503020]: Normal call termination. Reason: Server Failure
    16:33:06.062 [CM503016]: Call(34): Attempt to reach <sip:901483401176@10.1.39.6:5060;user=phone> failed. Reason: Server Failure
    16:33:06.062 [CM503003]: Call(34): Call to sip:01483401176@spitfiretsp.net:5060 has failed; Cause: 500 Internal Server Error; from IP:83.218.143.18:5060
    16:33:05.718 [CM503025]: Call(34): Calling VoIPline:01483401176@(Ln.10000@Spitfire)@[Dev:sip:441234567890@spitfiretsp.net:5060]
    16:33:05.718 [MS210002] C:34.2:Offer provided. Connection(transcoding mode): 109.238.76.251:63833(63834)
    16:33:05.609 [MS201000] Use STUN server 'stun.3cx.com:3478'
    16:33:05.593 [MS101005] STUN request failed for ports 9020,9021 on STUN server 'stun2.3cx.com:3478'
    16:33:02.484 [CM503004]: Call(34): Route 1: VoIPline:01483401176@(Ln.10000@Spitfire)@[Dev:sip:441234567890@spitfiretsp.net:5060]
    16:33:02.484 [CM503010]: Making route(s) to <sip:901483401176@10.1.39.6:5060;user=phone>
    16:33:02.484 [MS210000] C:34.1:Offer received. RTP connection: 10.1.39.10:57900(57901)
    16:33:02.484 Remote SDP is set for legC:34.1
    16:33:02.484 [CM505001]: Ext.100: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/7.3.14] PBX contact: [sip:100@10.1.39.6:5060]
    16:33:02.484 [CM503001]: Call(34): Incoming call from Ext.100 to <sip:901483401176@10.1.39.6:5060;user=phone>
    16:33:02.484 [CM500002]: Info on incoming INVITE:
    INVITE sip:901483401176@10.1.39.6:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 10.1.39.10:2048;branch=z9hG4bK-via207j80kn0;rport=2048
    Max-Forwards: 70
    Contact: <sip:100@10.1.39.10:2048;line=aoky1g67>;reg-id=1
    To: <sip:901483401176@10.1.39.6:5060;user=phone>
    From: "john blogs"<sip:100@10.1.39.6:5060>;tag=w1avo00d56
    Call-ID: 3c4cd2abe6a2-mg6h6rv7idho
    CSeq: 2 INVITE
    Session-Expires: 3600;refresher=uas
    Min-SE: 90
    Accept: application/sdp
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c02185c2e58:be730189c4068d512f1d8ae0b2c5d646",uri="sip:901483401176@10.1.39.6:5060;user=phone",response="bf8a9e6d025e4228d68e73875b3082e1",algorithm=MD5
    Supported: timer, 100rel, replaces, from-change
    User-Agent: snom320/7.3.14
    Allow-Events: talk, hold, refer, call-info
    Content-Length: 0
    P-Key-Flags: keys="3"
    Any ideas why that might be ?
    Olly
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Oliver,
    Its quite generic, a suppport ticket would probably be the best way to go, do you have a support contract? IF you run a wireshark capture it would be able to give you some more info as to why this would be happening.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    Hi, can you try using Stun-less mode?
    Go to Settings > Network > Stun Server > Turn off Stun server, and specify your Public IP there.
    Also make sure you have the correct range of ports open on your firewall.
