- Joined
- Aug 13, 2007
- Messages
- 70
- Reaction score
- 0
Have a system that's working swimmingly with all local and long-distance calls here in the States, but I'm not able to make any international calls. The phone's dial plan is configured correctly for international calls. For whatever reason, I keep getting an error 480 on any attempted international calls. Logging, followed by additional details below:
CM104008] Call(1130): Call from Ext.225 to 011617559705XX terminated; cause: 480 Temporarily not available; from IP:192.168.0.1
09:31:45.735 CallConf:nProvisional [CM103003] Call(1130): Ln:10019@Veracity is ringing
09:31:45.344 MediaServerReporting::STUN [MS101003] Call(1130) Ln:10019@Veracity: Possible firewall problem. Address mapping failed on STUN server 192.168.0.12:3478 for local address ":9088"
09:31:39.219 CallConf:nIncoming [CM103002] Call(1130): Incoming call from 225 (Ext.225) to sip:[email protected]
Router: Edgewater Edgemarc 4500 (192.168.0.1)
Server: Win 2003 Server Standard (192.168.0.12)
Endpoint: Linksys SPA-922 running Firmware 5.15 (192.168.0.28)
VOIP Provider: Veracity communications w/ a 10-channel SIP trunk
I'm thinking the router is timing out the call prematurely, but I could be mistaken. Any thoughts?
-Ryan
-Ryan
