Solved International format issue
Discussion in 'Android' started by TLA, May 23, 2017.
  1. TLA
    TLA
    Jan 21, 2017
    12
    When I call, for example, +33987654321 the call log show that 987654321 was dialed.
    When I call, for example, 0033987654321 the call log show that 0033987654321 was dialed.
    Only the second format works.
    Is there a way for 3CX to format the dialing correctly with the + sign?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    241
    12
    Go to Management Console > Settings > E164 Processing and disable Process E164 Numbers
    I hope this will help you
    Thank you
  3. TLA
    TLA
    Jan 21, 2017
    12
    Thanks for your reply, it worked perfectly.
