Internode Nodephone Australia
Discussion in '3CX Phone System - General' started by Vincent709, Jan 10, 2018.
  1. Vincent709
    Jan 10, 2018
    Hi guys.
    I was just wondering if anyone knows why NodePhone was removed from the SIP Trunks list for AU.
    We are on NodePhone and I need to know what settings to use in the configuration.
    I'm using G729 on my extensions and Trunk at the moment but it sounds pretty awful. I'm not sure how to configure all the other settings as well.
  2. pact
    pact New Member
    Dec 16, 2009
    202
    36
    TPG were not interested in paying the certification fee to have Internode re-certified.
    As for codecs, go with G711, we've found G729 on a direct SIP registration is ok, but via 3CX doesn't play ball.
  3. Vincent709
    Jan 10, 2018
    Thanks for the reply. It's a shame that G729 doesn't play ball. That's one of the main reasons we paid for the upgraded license.
    So should I just add G.711 A-Law and delete the rest? I remember looking at the packet trace and Nodephone would send a G729 down even when I only have G.711. I'm not sure if it gets changed by Nodephone or converted by 3CX if this happens.
    Also I'm not sure about Advanced Call Options:
    PBx Delivers Audio
    Supports Re-Invite
    Support Replace
    Put Public IP in SIP VIA Header
    Force Invites to be send to IP of Registrar
    SRTP
    Re-Register Timeout
    Select which IP to use in 'Contact' (SIP) and 'Connection'(SDP) fields
    Inbound Parameters:
    Call Number/Name Field Mapping:
    Call Source Identification
    And all the values in Outbound Parameters
    Should I leave them all as default?
