Into PSTN lines not applies templates!
Discussion in '3CX Phone System - General' started by netmatika, Apr 28, 2007.
  1. netmatika
    Feb 16, 2007
    17
    Hi all,
    i've installed new version and i've tried to apply the template on PSTN lines...i click on GXW 4104 and press apply button...the system says "the template was apply!" but isn't true !
    3CX retains the first hardware into combo box.
    best regards
    Netmatika
  2. kevin
    kevin Member
    Nov 23, 2006
    318
    Hi there
    The template -=DOES=- apply.
    The interface however does not keep a record of which template is applied.
    We will consider adjusting this to make the interface more user friendly.
    Thank you for your comments.
