inum
Discussion in '3CX Phone System - General' started by sigma1, Jul 27, 2010.
  1. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Anyone using them? I decided to get an inum DID today and I like the concept. 3CX works well (as expected), just make sure you make a Outbound rule to add the required prefix (if needed) from your trunk provider.
  2. assad-sit37
    Aug 6, 2012
    12
    Hi Sigma1,
    Don't know if you still use Inum, but do you have any détails on how to configure on 3CX to get it working?
  3. sigma1
    Nov 20, 2009
    542
    Nothing more than adding a proper outbound rule. Start with 883 and 15 digits long.
    You can reach us at 883510001342132
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    The problem with inum is very few providers can route calls to inum number (for most of them this is unknown destination). I was using one number via callcentric (not available anymore), it was configurable as DDI number at callcentric trunk.
    Regards
  5. sigma1
    Nov 20, 2009
    542
    Lots of things at one time worked at Callcentric, post disaster they are still struggling to get on their feet. Many carriers (including us) will terminate iNum. On their site you can find a very long list of carriers that do.
