Invalid config templates
Discussion in '3CX Phone System - General' started by scythe000, Dec 5, 2014.
  1. scythe000
    Nov 8, 2011
    66
    I've Polycom SPIP430s and a few 550s. 3CX, inside the template file called (MACID).cfg, it points the phone to phone1_21x.cfg. In order for the phone to work, I have to change that to (MACID)-phone.cfg.
    Any idea how I can make 3CX generate this file properly?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Kindly detail further what 3CX Phone System version you are running, on what service pack, and what firmware is running on the phones.
  3. scythe000
    Nov 8, 2011
    66
    3CX version 11 SP4.A (Latest)
    SPIP 430 firmware 3.2.0.0157? I'm not exactly sure.
    Thanks!
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Polycom templates and supported firmwares have been renewed in v12.5.
    If you'd like you can give it a try and see if your issues persists, however please note that v12.5 is still in beta stage.
  5. scythe000
    Nov 8, 2011
    66
    For the time being, I'm stuck on version 11, because it's running on a 32 bit version of windows server 2008. Is there no way to fix this for v11?
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    I'm afraid those new templates/firmwares have not been tested for v11.
