Solved iOS 10 - New Release Bug
Discussion in 'iOS' started by supplenta, Nov 25, 2016.
  1. supplenta
    Oct 3, 2012
    35
    I downloaded the new 3CX last night via the App Store and I have noticed a problem with it this morning.
    When inside of the 3CXPhone app, there is no access to Notification Centre or Control Centre. I have swiped several times but nothing happens.
    Please correct this.
    Thank you.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    How can an application take control over iOS' Notification/Control Center?!?
    We have several iOS models iPhones/iPads, add also external testers - we have no such problem.
  3. Vali_3CX
    Dec 12, 2008
    1,527
    71
    As an additional note:
    If, by "When inside of the 3CXPhone app", you mean the new, "CallKit" answering call phone interface - that one is entirely controlled by the iOS.
    To verify this, call your device via a regular GSM call, and let the device' phone or FaceTime to show the same answering interface; these are definitely not 3CX apps, and - as you can see - the Notification/Control center are made inaccessible by the iOS.
    So, if this is the case you referred, please post your suggestion here:
    http://www.apple.com/feedback/iphone.html
    Regards
    vali
