Solved iOS 3CX App not show Date Time
Discussion in 'iOS' started by Sunchai N., Dec 11, 2017.
  1. Sunchai N.
    Jul 1, 2017
    6
    Date Time on Recents not show, show (null), when Date & Time on iPhone not set to "24-Hour Time"
    Is it possible to fix this?
    [​IMG]
    Device Info
    Phone Model: iPhone
    Generation: X
    Firmware Version: 11.2
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi|3G
    Server: External
    Thank you.
    Sunchai N.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    Hi Sunchai
    Thanks for reporting it, it looks something new - we'll check it and we'll keep you informed.
    vali
  3. Vali_3CX
    Dec 12, 2008
    1,527
    71
    @Sunchai N. please check your PM, I will need some assistance.
  4. Vali_3CX
    Dec 12, 2008
    1,527
    71
    OK, the issue has been fixed and is available on Beta 15.2.12.299
    I'm grateful to @Sunchai N. for spotting it, because it seems to affect all iOS 11.x devices set on a non-english language and displaying time in 12h format.
  5. Sunchai N.
    Jul 1, 2017
    6
    Dear Vali,
    Thank you for your support. I will wating for update.
    Sunchai N.
  6. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi @Sunchai N.
    15.2.12.316 is released, so you can check if it's working OK now - please let me know, I consider the issue important one
    vali
    jed likes this.
  7. Sunchai N.
    Jul 1, 2017
    6
    Dear Vali
    Problem is solved. Thank you very much.
    Sunchai N.
