IOS 3CX client will receives any prompt when IOS 3CX client on standby mode receives any message
Discussion in 'Ideas' started by wuyu, Sep 5, 2016.
  1. wuyu
    Jun 26, 2012
    18
    21
    I test the chat in the IOS 3CX softphone, and when IOS 3CX softphone is on standby mode( or on push mode), if we send any message to it, there is not any voice prompt, after we run the IOS 3CX softphone, there will be the voice prompt.
    The IOS 3CX softphone is usually on standby mode, because we need to check the other applications sometimes, we hope when the IOS 3CX softphone is on standby mode, it still can have the voice prompt or any other prompt when IOS 3CX softphone receives any message.
