Solved ios client for 3cx ver 12.5
Discussion in 'iOS' started by dewittds, Oct 24, 2016.
  1. dewittds
    May 26, 2016
    We need ios client for 3cx ver 12.5 and found that the iphone app store only has version 14. Where can I download this version. I had been told to try cnet.com but they just have link to itunes.
    Thanks for any help,
    david
  2. Anonymous
    Anonymous Guest
    There is no (standard) way to get software on an iphone without using the app store. There really are two options
    1) Convince 3CX to make the current ios 3cxPhone backward compatible (which imho is necessary if not already done)
    2) upgrade your 3cx to the current version.
    Have you tried the latest version of ios 3cxPhone?
