iOS Client IPv6 Issues with Rogers LTE
Discussion in 'iOS' started by admin@faserver.ca, Jun 12, 2018.
  1. admin@faserver.ca
    Jan 29, 2016
    5
    As of this morning my mobile devices will no longer register when on Rogers LTE. They were working fine previously and are still working when connected to wifi. The mobile clients are running the latest version of the mobile app. (15.5.15.388)
    The firewall tester reports no issues and our server version is: 15.5.12663.5
    The only issue I noticed is the mobile clients all now report IPv6 on the dashboard. A
    Any suggestions?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,516
    71
    It might be possible that Rogers (suddenly) is blocking non-standard ports (mainly 5060/5090)?
  3. admin@faserver.ca
    Jan 29, 2016
    5
    Is there any way to verify or test this?
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,469
    286
    Set up a firewall rule from port 5060 to an internal webserver on port 80.
    (Depends on firewall make/model)
    Then on that device goto IP:5060 in web browser to see if you get that particular webserver or not.
    Even if your 3cx is in the cloud, this is checking traffic on port 5060 only to a random webserver.
  5. admin@faserver.ca
    Jan 29, 2016
    5
    Hi, thanks for this tip. We have tested this and port 5060 is open and operational when on Rogers network. It seems that this issue pertains to IPv6.
  6. Vali_3CX
    Dec 12, 2008
    1,516
    71
    To me, what is intriguing is following:
    "the mobile clients all now report IPv6 on the dashboard"
    So, you have several iOS devices, all worked properly using Rogers until now, when suddenly all appeared as IPv6 and stopped working?
    Also, just to be clear: when you say "dashboard" you mean Management Console's Phones panel? "IPv6" is also shown on client's display, on top-left under account name?
    Why I'm asking: currently we don't have IPv6-related issues reported about iOS client, and this includes several members of our Beta program who uses Rogers provider in Canada. As far as I know, Rogers provides dual-stack IP, so if clients suddenly shows IPv6 on the display, that means their local IPv4 interface has (somehow) gone.
  7. dezmocom
    Oct 15, 2014
    13
    13
    HI Vali
    I just got the same issue form the users that are on Rogers/Fido (both are same network) and using LTE network. The app is stating IPV6 (see below attachement).
    When in WiFi no issues ... voice works. Chat messages are still received but no voice whatsoever on the LTE network.
    Please help :)
    Andreas
  8. Vali_3CX
    Dec 12, 2008
    1,516
    71
    Hi Andreas, welcome back :)
    Few questions:
    - the IPv6 was displayed always when using Rogers, or it appeared suddenly and the client stopped working?
    - it's possible to associate this issue with, let's say, a major change, such an iOS upgrade to 11.4/12, or a change in policy/setting made by provider?
    - your MyPhone PBX uses 443 or 5001 port?
    - since 3G triggers "out-of-office" connection, can you play a bit with account settings such tunnel on-off and connection TCP-UDP, to see if there are any changes in behavior?
    vali
  9. dezmocom
    Oct 15, 2014
    13
    13
    Hi Vali,
    The client is using :
    • Client cannot tell me if it was there or just showed up :(
    • They are on iOS 11.4 and problem has shown up only last few days
    • No change in the Policy
    • I have attached what is showing on the client's iPhone when going to whatismyip.com - you can see there is only IPV6 and no IPV4. On Bell's network I get both on my Samsung Note 8
    • the PBX is set to listen 5001
    Hope this clarifies.
  10. Vali_3CX
    Dec 12, 2008
    1,516
    71
    Thanks for update, Andreas.
    Can you please tell your customer to go to account settings and try following cases:
    - with tunnel ON
    - with tunnel OFF and transport TCP
    - with tunnel OFF and transport UDP
    Since MyPhone connection is working on 5001, it means Rogers don't block nonstandard ports; the cases I mentioned above are trying to check for SIP traffic and packet fragmentation.
    Also, since MyPhone connection seems to work (I see status "Available") tell him to go to More and try a Re-Provision, or Resend credentials for a fresh welcome eMail, or, if he has a webclient nearby, a QR provisioning.
    Please let me know.
  11. Brendan D.
    May 5, 2018
    5
    I have a client experiencing the exact same issues, Firewall check passes all green. Same symptoms, rogers LTE, client shows IPV6 on client interface. no calls come in or out. They tried all three scenarios listed in the last post with no success. Were you able to resolve this
    dezmocom?
  12. Vali_3CX
    Dec 12, 2008
    1,516
    71
    Your customer since when used Rogers LTE on 3CX client? One year, two years, one month?
  13. Brendan D.
    May 5, 2018
    5
    2+ years, The only change recently was the upgrade of the 3CX server to 15.5.13103.5 and the IOS client to the latest version. We already also tried re-registering using a welcome e-mail.
  14. Vali_3CX
    Dec 12, 2008
    1,516
    71
    Thanks for info - I'm trying to "pair" this issue with an event, to tighten the circle around, that's why I'm asking these questions.
    We released the 3CX client one month ago (May 18th) - since then until now, your customer used it with Rogers LTE? If yes, the "IPv6" display indicator was shown on the display?
  15. Brendan D.
    May 5, 2018
    5
    It did not say IPV6 when it was working. It only started when calling stopped working.
  16. Vali_3CX
    Dec 12, 2008
    1,516
    71
    It's important to know if the issue didn't happen in 15.5.14 but appeared exactly when your customer updated to 15.5.15, because it would be a strong hint we added a bug in .15
    But, if .15 worked properly for some time and suddently it started to show IPv6 and not connecting, it would be a very strong hint that something changed in Rogers LTE as carrier. Have a look at this article from yesterday:
    A VPN-over-LTE issue is once again affecting some Rogers wireless subscribers
    https://mobilesyrup.com/2018/06/20/rogers-troubleshooting-vpn-over-lte-issue-for-affected-users/
  17. Brendan D.
    May 5, 2018
    5
    Vali_3CX likes this.
  18. Vali_3CX
    Dec 12, 2008
    1,516
    71
    Thanks for update, Brendan.
    I've got some 3CX client logs - well, I've always assumed that, in terms of local network interfaces, a mobile device is far simpler than a desktop computer; it seems I was very wrong: this particular device has 14 (yes, fourteen) active local interfaces: en, ipsec, bridge, almost all IPv6. And the two DNSs also IPv6.
    3CX client has IPv6 (including dual stack) support since two years ago (january 2016) and was known to work OK - until now - with Rogers carrier (dezmocom here helped me then with feedback). Builtin tunnel has also been updated to properly handle IPv6 since almost a year. So, from my point of view, no matter if IPv6 is shown on the display, the 3CX client is (should be) prepared to deal with, as it proved with T-Mobile US or Verizon. If not, to me it means either it had a well hidden bug which surfaced now, or there is a problem with the carrier's conditions - I'm not excluding any.
  19. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    I'm having the same issue here when not on wifi. Rogers iphone 7. If you need any logs or captures let me know happy to help get this resolved.
  20. Vali_3CX
    Dec 12, 2008
    1,516
    71
    On all the logs I've got, with WiFi disabled, all local interfaces (including DNSs) are IPv6 - in this case, how it's expected 3CX client to not show "IPv6"? And how it's expected to "enforce" 3CX client to work on IPv4 when there is no IPv4?
    I'm just curious, there is somebody who called Rogers tech support? To ask them at least why, unlike T-Mobile, there is not at least one IPv4 DNS?
