Solved iOS-client problems
Discussion in 'iOS' started by SimWhite, Dec 21, 2016.
  1. SimWhite
    Dec 19, 2016
    17
    I'm tried to test iOS version of 3CX client and it seems not working.
    1. I'm installed 3CX client on my desktop and 3CX client on my iOS device connected to the same extension. When I try to make a call to this extension desktop client didn't ring at all. iOS client rings when iOS-device is sleeping but when I try to answer it's disconnect. On the caller side I get "busy".
    2. I try to use only iOS-client without desktop. The same problem. I can't make a call in both directions with iOS inside the PBX. I can make a call to the outside trunk only.
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    245
    12
    Re-register/Re-provision both clients and make sure that both client are on hook.
  3. SimWhite
    Dec 19, 2016
    17
    Already tried more than 20 times.
    UPD: Interested fact. When I try to call from one iOS-client extension to another desktop-client extension (there is no any more clients connected) there is no any ringer on desktop but I see "In a call" status or caller. And when I close iOS client and put phone to sleep the status of this extension is still "In a call".
    UPD2: It is passed more than 40 minutes and the extension status is still "In a call".
    I use the latest versions of software.
    #3 SimWhite, Dec 21, 2016
  4. Marios Neophytou
    Mar 1, 2016
    245
    12
    Can you give me more details?
    1. What is the configuration you currently have on the iOS?
    2. Is your PBX running locally or remote?
    3. What is the Version of your PBX?
    4. Do you have tunnel enable on these extensions?
    5. What transport protocols are you using? (UDP/TCP)
  5. SimWhite
    Dec 19, 2016
    17
    1. Interface: xxx.3cx.eu, UDP, only secure, enabled push, re-provision, tunnel enabled.
    2. Remote. NATed. Firewall tests passed.
    3. Activated PBX 15.0.60903.0
    4. Yes.
    5. UDP.
  6. StefanW
    Jun 2, 2009
    1,210
    85
    when you are remote to your PBX or 4G then you also need 5090 TCP (firewall checker only looks at tcp)
  7. Marios Neophytou
    Mar 1, 2016
    245
    12
    Do you have "only secure" on iPhone only? If yes then do so for all of your clients.
  8. SimWhite
    Dec 19, 2016
    17
    I have both TCP and UDP 5090 ports opened, I use this document for ports forward — http://www.3cx.com/docs/3cx-phone-system-v14-ports/ and I have "only secure" feature activated on both extension. And as I understand "only secure" feature used for voice transmission but we have a problem with signalling.
  9. Marios Neophytou
    Mar 1, 2016
    245
    12
    Only secure (SRTP) option use for secure your communication. Make sure that you have all the appropriate ports open (9000-9500).
    Is this happening with Normal RTP mode also?
  10. SimWhite
    Dec 19, 2016
    17
    UDP ports from 9000 to 9500 are forwarded. With the normal RTP mode it seems to be working but I need encrypted calls on public networks.
  11. complex1
    complex1 Active Member
    Jan 25, 2010
    764
    39
    I have the same issue with my iOS clients.
  12. SimWhite
    Dec 19, 2016
    17
    I made some tests and it seems the problem is not in iOS clients. As I see the problem with the implementation of sRTP (RTP mode secure only) itself. It didn't work with desktop clients too.
