Solved iOS Client Receiving Unsupported 3CX Phone System Message
Discussion in 'iOS' started by techclarity, Nov 16, 2017.
  1. techclarity
    techclarity New Member
    Nov 14, 2014
    109
    50
    We have several clients that are still on 3CX version 15. It looks like they updated the mobile client today and they are now receiving a message stating that "We have detected an old an unsupported version of 3CX Phone System. This client will not run correctly with this version and will stop working all together on 1/1/2018. Please contact your administrator to upgrade 3CX to v15.5"
    Why is this message showing? Isn't version 15 still a supported version? Is there a way to turn this off?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    It means they have a V15 with NO service packs applied.
    Minimum requirement is V15.5 SP1.
  3. Vali_3CX
    Dec 12, 2008
    1,527
    71
    To keep this topic updated:
    Today we just released 15.2.9.284, which also fixes the confusion generated by the "Unsupported PBX" message - so it will be shown only for PBXs < 15.0.
  4. techclarity
    Nov 14, 2014
    109
    50
    Awesome! Thanks for the update Vali!
  5. jed
    jed New Member
    Feb 1, 2010
    153
    48
    @Vali_3CX
    What will actualy happen on 1/1-2018 if a customer dont upgrade their v14 PBX to v15.x regarding their SoftPhones on Android / iPhones.. Will they not work at all, or?
    Thank you.
  6. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi Jesper
    Most probably, we'll increase client's minimum supported version to 15 and it will behave as it does now when attempting to connect to a V11 or V12 PBX - will disconnect and show an "update PBX" message.
  7. LyonAdmiral
    Aug 10, 2015
    51
    Our institution is in the same boat, we are running V14 SP3, and we cannot upgrade to V15>, we lose functionality with our current phones which are a mix of Cisco and Polycom phones. What can we do? Is there a way to rollback to the older version of 3CX Client for IOS?
  8. Vali_3CX
    Dec 12, 2008
    1,527
    71
    I cannot provide you "the" answer, because I don't have it, unfortunately. Basically, it's a marketing/sales question - my advice is to contact our sales team for more information.
