IOWA Sip Providers
Discussion in '3CX Phone System - General' started by tazz, Sep 23, 2007.
  1. tazz
    tazz New Member
    Sep 12, 2007
    124
    Has anyone noticed how difficult it is to locate a SIP provider that doles out IOWA phone numbers? Why is this state isolated out of the VOIP service?
    Any Thoughts?
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I would have thought you would have said how EASY it was :) . Lots of free Iowa inbound numbers available, and you can source outbound seperately based on best price. Try http://www.sipnumber.com/
  3. tazz
    tazz New Member
    Sep 12, 2007
    124
    Maybe better said in regards to an area code of Iowa. Sipnumber & Freedigits chose the area code for you Just try once and go to VOIP Web sites Iowa is never listed.........
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Hmmmm... Guess I understand now. For a Canadian specific Iowa area codes were not an issue, I just keep an Iowa number for relatives in the general area :eek: . Good luck.
