IP address change on SBC
Discussion in '3CX Phone System - General' started by Heath, Aug 26, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    122
    how do you change either the primary or failover IP address in the SBC
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,248
    175
    Hi Heath,
    Is this on Linux, Raspberry pi or Windows SBC variants ?
  3. Heath
    Heath New Member
    Aug 12, 2017
    122
    It's running on windows
  4. eddv123
    Aug 15, 2017
    1,248
    175
    Hi Heath,
    I only really use the Linux and Raspberry Pi variants (no licencing required), however from my experience I think you would be best off simply re-installing it with the desired credentials.
    Just use add remove programs and run the installer again, should not take a couple of minutes. However the phones will require a reset and re-provision if using a preferred phone model which supports PnP Provisioning.
