IP Address Change
Discussion in '3CX Phone System - General' started by cbongard, Nov 21, 2011.
  1. cbongard
    Nov 8, 2011
    40
    I prepared a new 3CX server at our main office, modified the IP address, and shipped it out to our remote office. Now, none of the phones will provision and connect. I have the Option 66 set on our DHCP server out there, but the phones refuse to connect. I do see them attempting to provision in the server activity log, but see the following information:
    [CM302001]: Authorization system cano not identify source of: SipReq: SUBSCRIBE MAC%3 etc.
    And shortly therafter, the subscr. is terminated.
    What am I missing? Why is it so difficult to change the IP address on a 3CX server? Why can't we use DNS names to make the 3CX IP Address changes easier?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Go to advanced settings - custom parameters and carefully change manually the address (several instances).
    Regards
  3. cbongard
    Nov 8, 2011
    40
    I had already changed all the instances and still receive this error. I also went through ALL the provisioning files and confirmed they all have the new IP address.
    Any other ideas?
  4. eagle2
    Apr 27, 2011
    1,085
    11
    No idea, no reason for this. Have you restarted your system ?
    I've changed the addresses many times, practically in each installation for a customer.
    Regards
  5. cbongard
    Nov 8, 2011
    40
    I rebuilt our phone system from scratch and ran in to the same problem. I am not sure why the scope Option 66 did not work, but the solution ended up being a static DHCP reservation for each individual phone, and assigning the Option 66 that way. Weird one, but could be a SNOM firmware issue.
