ip address's
Discussion in '3CX Phone System - General' started by jwnesbitt, Sep 19, 2009.
  1. jwnesbitt
    Sep 19, 2009
    48
    I installed my Phone system on a local IP address (192.168.1.52), but now I wish to set up an extension that is outside my local network
    I already have hamachi installed and that has generated an ip range of 5.
    My ISP does not offer a fixed IP, but I do have a account with Dynamic DNS, so could i use my DynDns address for the 3CX phone system or the hamachi IP ?
    How would i change it in the phone system
    thanks
    Jody
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    After doing a bit of research on Hamachi,
    Hamachi would work if you where using the softphone, it will not reliably pass traffic for hardphones.
    You can use the DYNDNS but reliability is going to be an issue.
  3. jwnesbitt
    Sep 19, 2009
    48
    hi
    thanks for the reply.
    I noticed on your website that you offer a simialr service, how do you do it with multiple locations?
    thanks again for the quick support
    Jody
  4. leejor
    10,360
    226
    I use DYNDNS with external extensions ,with no issues. Set up an account with whichever dynamic DNS service your router uses (most are free) and use that setting in the remote phone(s) in place of the server IP. Don't forget to enable STUN in the remote set too.
  5. jwnesbitt
    Sep 19, 2009
    48
    thanks for that
    do i need to append the port number in the settings as well
    ie: ...dynds.com:50??
    thanks
    Jody
  6. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    You only need the port info for accessing the web administration. Remote phones all use the same ports so you just need the ip address.
  7. leejor
    10,360
    226
    In SIP each phone/device there is a place to enter the IP address (location) of the server AND a place to enter the port. Some default this port to 5060 but if you happen to set up 3CX to use a different port, you can change this. Each device also has it's own port number. If you are running two phones at one remote location you will want to make sure that they don't have the same (internal) port numbers, use 5060, 5061, etc. Think of port numbers like apartment numbers, the mail (messages) won't get through if two apartments have the same number at that address (IP).
  8. tpinnovations
    Jul 30, 2009
    296
    Our servers are located on static IP blocks, so dynamic IP's will only change on the client side. We adjust re-registration times and use some proprietary network tricks to insure connectivity 100% of the time. The hardest problems we have are with certain connections were the ISP is issuing internally restricted class C ranges to the WAN side of the modem. In that case we generally have to send out a VPN end point.
    So long as at least one end of the VoIP system is static, there shouldn't be any problems.
