Solved IP Based authentication method on Trunk
Discussion in '3CX Phone System - General' started by Martin Schilder, Mar 7, 2018.
  1. Martin Schilder
    Dec 12, 2017
    Hello
    I configured an yeastar TG200 in order to route calls over the gsm network. In order to make this happen i followed the guidelines which tells that the authentication method should be set to "Do not require - IP Based"
    Outbound calls are working flawless but inbound the pbx throws a 407
    SIP/2.0 100 Trying
    Via: SIP/2.0/UDP 192.168.150.232:5060;branch=z9hG4bK1a60db9a;rport=5060
    To: <sip:0xxx@192.168.150.42:5060>
    From: "+316xxx" <sip:+31xxx@192.168.150.232>;tag=as1d49d203
    Call-ID: 34c324495355f34e2035bc276203be61@192.168.150.232
    CSeq: 102 INVITE
    Content-Length: 0
    SIP/2.0 407 Proxy Authentication Required
    Proxy-Authenticate: Digest nonce="414d53595a9fa6f672:1770e437074c164a2dc00f6f3597bd03",algorithm=MD5,realm="3CXPhoneSystem"
    To: <sip:0623193042@192.168.150.42:5060>;tag=bb13966e
    From: "+316xxx" <sip:+316xxx@192.168.150.232>;tag=as1d49d203
    CSeq: 102 INVITE
    User-Agent: 3CXPhoneSystem 15.5.9348.3 (9348)
    Content-Length: 0
    Based on the type of authentication i would not expect this.. Is there a way to work around this?
    Martin
  2. Martin Schilder
    Dec 12, 2017
    In the meantime i found the solution :) The device needs to be configured as "Add sip trunk" instead of "Add gateway"
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    281
    Glad to see the issue has been resolved and thank you for updating the thread with your solution
