IP Blacklist Should Be Under Security in The Settings Menu
Discussion in '3CX Phone System - General' started by JStellato, Oct 5, 2016.
  1. JStellato
    Dec 17, 2015
    33
    6
    It's confusing to have 3 locations to get to certain settings. IP Blacklist is only available from the dashboard, and not under settings and Security as you would think.
    All of the settings should have a shortcut from the Settings Menu.
  2. CBUTLER
    May 11, 2015
    51
    I had an issue earlier today in which I needed to remove some IPs from the blacklist. It took me 20 minutes to find that it was located under the dashboard and not the security settings :(
  3. Pastis
    Apr 16, 2015
    7
    took me 10 minutes to not find it until I come here ... thank you ;)
    of course it should be located under security settings....
